Full Brake Change... Expected costs..!
CGreen98
Drives: Polo 1.6 TDI SEL
Post by CGreen98 »
Hi Everyone,
I have a 2011 Polo SEL which under braking the steering wheel shakes uncontrollably... I have been to the local garage and my front right disk is warped (the SEL 90 has full disks all round no drums). The car has 50k miles and I think the discs have never been changed in this time. The last MOT recommended I change basically everything Discs and Pads all round next time round.
How much should I expect to pay for a full set of brakes?
Thanks CamImage
Re: Full Brake Change... Expected costs..!
Really depends whether you'll settle for a pair of textar brakes of if you want to go full brembo/Zimmermann/ate
256x22mm front brake discs around 50-100 GBP
Pads shouldn't be that expensive, id reckon about 25 gbp an axle
232x9mm rear rotors come in at anywhere between 25 and 50.
Just look around a bit on eBay.
