Just fitted some 17" alloys on the polo with an undetermined centre bore. I know that the car is 57.1 and test fitted the alloys hoping they'd fit. I put them on with no trouble and there's no wiggle or movement.
However I've contacted the manufacturer of the wheels and they say they have a centre bore of 72.6 which is quite a way off the cars CB. Would I not see some movement or issues with that big of a difference?
I've ordered some spigot rings just in case
Spigot rings
Ricmondo
- Drives: Polo Blue GT
Re: Spigot rings
You will probably only notice when the movement loosens or breaks the wheel nut and you become a Reliant Robin, or worse!
On modern cars the centre spigot holds the wheel in place, the wheel nuts are a secondary fitment.
Fit the adaptors or go back to the original wheels. Not wishing to be melodramatic but it's a potential killer that should not be underestimated.
Willni
- Drives: Polo '14 6R, Golf 07' Edition 30
Re: Spigot rings
Get a set of spigot rings, they're there so the weight of the car goes through the car and not the 5 bolts, hence why standard alloys don't come with spigot rings.
Ideally you'll want metal spigots but plastic work just as well
Re: Spigot rings
Will I be okay for a few days whilst I wait for them to be delivered?Ricmondo wrote: Mon Aug 07, 2017 7:54 pm You will probably only notice when the movement loosens or breaks the wheel nut and you become a Reliant Robin, or worse!
Ricmondo
Re: Spigot rings
Legally your car is unroadworthy, your insurance is invalid, you are in danger, so am I if you drive near me....what do you think?
Re: Spigot rings
Okay so I got the rings today, went to put them on one of the wheels and..it didn't go in. It seems as if there's already a thick metal ring in there that won't budge. Am I right in thinking the previous owner must have fitted rings already? They won't come out at all, almost like they're welded in thereRicmondo wrote: Mon Aug 07, 2017 11:46 pm Legally your car is unroadworthy, your insurance is invalid, you are in danger, so am I if you drive near me....what do you think?
Re: Spigot rings
If the wheel manufacturer advised the centre bore of your wheels is 72.6 and you said in one of your earlier threads that they were previously fitted to an older model Polo (same centre bore as your Polo 6r at 57.1) then yes, it's highly likely that your new wheels already have the correct size spigot rings fitted.Matte6r wrote: Wed Aug 09, 2017 7:30 pmOkay so I got the rings today, went to put them on one of the wheels and..it didn't go in. It seems as if there's already a thick metal ring in there that won't budge. Am I right in thinking the previous owner must have fitted rings already? They won't come out at all, almost like they're welded in thereRicmondo wrote: Mon Aug 07, 2017 11:46 pm Legally your car is unroadworthy, your insurance is invalid, you are in danger, so am I if you drive near me....what do you think?
Have you measured the diameter of the centre bore (reverse side of wheel) of your new wheels with the existing metal rings fitted? Is it the same as the centre bore of your original wheels?
