I have a requestion regarding my 6N2 GTI. The cam cover paint is starting to wear and hence it could use a repaint.
Now the issue starts..... I read various stories that removing the cam cover is a hell of a job due cams needs to be removed (if I'm correctly).
Therefore my question is, are there any GTI drivers around here having done theirs? And so, how did you do it? Remove it (and how can you properly do this) or repaint it whilst installed? In that last case how did you properly prep it? That is my main concern when repainting in installed state.
Many, many, many thanks for your help in advance!
Cheers Marvin
