Looking to lower my 2010 1.2 6r on H and R springs
Can anyone tell me what exactly I'll need? What size sockets will I need?
Tools needed for changing springs
Re: Tools needed for changing springs
It appears you don't really know what you're doing. The rear is easy to do, you'll need a 15 and 16mm socket to release the shocks from the beam axle.
The front is a lot more difficult due to the McPherson struts. The spring is coiled around the shock absorber.
If you don't know what you're doing, go to a garage. A suspension spring to the face can easily kill you.
If you do feel like you're able, and you're really really really sure...
You'll need
- Set of sockets (10-17mm) and a 22mm for the top strut
- Set of torxes for the strut and the connecting rods
- An Allen key for the top of the strut
- Knuckle spreader tool
- Spring compressors
You'll need
Just never done it before and have never looked into it before so no I really have no ideaiichel wrote: Thu Sep 14, 2017 9:01 pm It appears you don't really know what you're doing. The rear is easy to do, you'll need a 15 and 16mm socket to release the shocks from the beam axle.
You'll need
I'm assuming I'll be okay providing I'm careful with the springs and use the compressors properly.
Thanks for that list
Well, if you are willing to hard the hard way, buy a copy of the Haynes Repair Manual, it is only for the 6R Polo, but a lot of stuff is the same for both the 6R and the 6C, certainly as far as the suspension is concerned. You should add a large socket for the RHS drive shaft into that list of tools. Oh and a large multi spline bit for the strut clamping bolt - and maybe a few more tools as well as trolley jacks and axle stands.
