Glass in heater blower!
Cheesebrains
- Drives: 6R r line
I've had to have a screen in my polo n there's still glass shards in the blowers and think in the heater box, what's best way to get it all out, before it sends me blind?!!!
Re: Glass in heater blower!
Easy answer, take that car back to the company that replaced that windscreen, have messed up and now need to sort that out.
Or -
By the way, I'd reckon that the bits of glass will have fallen down into the demister outlets, so barring removing probably the dashboard, then dis-assembling the air distribution pipe work and box and clearing any remaining bits of glass out, this will continue to be a problem - it would not have been a problem if a proper windscreen company/operator had carried out that task.
Or -
If your car insurance company demanded that you used this company, take it up with them and make sure that you make it their problem and not your's!
Or -
Or -
Cheesebrains
- Drives: 6R r line
Thanks for the reply,
The screen was smashed when I bought the car so can't blame the glass company, was really hoping someone had the best solution to getting to the pipes/box!
If you remove any trim bits that are covering the under dash area, you might find that you can mutilate the ducting to get inside, and still make it "good" again - just a thought as removing the dash would be a real pain in the bottom I'd think!
