funky electrics
Posted: Thu Aug 12, 2004 11:25 pm
by M@Turner
Yesterday i was tinkering in the boot, and think i may have shorted something as i heard a crackle come from the boot interior light. When i tried plugging the interior light back in, it didn't work. And also, when i locked the car, the alarm made a couple more extra beeps when i locked it.
This morning i decided to check the fuses but took a couple of the wrong ones out before i found a blown fuse.
Unfortunately i didn't have a replacement fuse so left it out and went to work. On my way home i had the window down and pulled up to my house with the window still down. I turned the engine and ignition but my window wouldn't go back up like it used to, before the tinkering. And also my interior light didn't work. However, when i locked the car, the alarm beeped just the once like it used too.
Any ideas whats going off. Or should i just wait and see what happens when i replace the fuse. :!:
Posted: Thu Aug 12, 2004 11:29 pm
by david burton
wait and see! Check all of em too.... The window fuse should be on a different circuit, so have a close look at em all - could be a coincedence.
Maybe the light circuit is on the voltage drop circuit on the alarm or something? who knows!
Posted: Fri Aug 13, 2004 5:41 pm
by mikegti
that does sound odd... what were you playing with?
has your alarm always beeped? mine doesn't beep at all :?:
Posted: Fri Aug 13, 2004 10:13 pm
by M@Turner
I was removing my boot interior light to install my LED light tube (home made) and i shorted the circuit.
Went to Halfords and purchased a new Fuse and everything is back to normal.
Mikegti: as for the alarm, when you lock the car with the RCL, the door pins drop down indicaters flash and it makes one beep.
When you open the car, pins come up indicaters flash and it beeps twice.
Thats what i think happens anyway. :roll:
Posted: Sun Aug 15, 2004 2:19 am
by cyhliu
Hmmm....interesting...I don't think mine bleeps either...must check it out sometime...
Posted: Sun Aug 15, 2004 3:08 pm
by M@Turner
It could be one of the many different variations between the GTi specs.
We will all have to compare our polo's at the Polo Show.
only 5b days to go! :lol:
Posted: Mon Aug 16, 2004 12:26 pm
by gti MAD
My alarm defo doesnt beep at all either
Posted: Mon Aug 16, 2004 12:41 pm
by Prash
nope mine doesn't beep :P
Posted: Mon Aug 16, 2004 1:56 pm
by cyhliu
It may be something that could be changed via the VAG-COM computer...may be?
Posted: Mon Aug 16, 2004 5:26 pm
by Si_GTi
My RCL doesn't beep, just the usual flashing indicators. Would be nice if it could be programmed to beep though. Sometimes I park up, walk into work, turn on the PC, make a cuppa and then wonder if I've locked it!! D'oh :roll:
Posted: Mon Aug 16, 2004 5:45 pm
by hurricane
my alarm and doors lock themselves after about 30 - 40 seconds if i forget .no beep though. :shock:
