Radio
davemillson1212
- Drives: 2003 1.2
Radio
Hi ive bought a radio wired it up matching all wires but when i turn it off it says bye but still stays illuminated so i have to keep unplugging it if i dont like the other week it flattens my battery anyone know anything please
Sent from my SM-A320FL using Tapatalk
Re: Radio
What polo and what radio for a start
davemillson1212
- Drives: 2003 1.2
Re: Radio
Vw polo 2003 1.2 and its this radio off eBayalexperkins wrote:What polo and what radio for a start
Re: Radio
Have you wired the ignition and permanent feeds around the correct way?
Also where did you take the illuminate feed from
davemillson1212
- Drives: 2003 1.2
Re: Radio
Your asking me now m8 i just wired all colours matching from stereo to wires on plugalexperkins wrote:Have you wired the ignition and permanent feeds around the correct way?
Re: Radio
Can you post some pics up of the looks behind the radio? Is it forgetting it’s settings when it’s turned off?
davemillson1212
- Drives: 2003 1.2
Re: Radio
Here some picsalexperkins wrote:Can you post some pics up of the looks behind the radio? Is it forgetting it’s settings when it’s turned off?
Re: Radio
That doesnt look too good mate. Why are the orange and pink wires not connected to anything?
Silly question, but why have all those wires been cut?
You might be wise to ask the seller for a replacement harness. You shouldnt need to cut any wires.
davemillson1212
- Drives: 2003 1.2
Re: Radio
Not sure i did get a full refund off him and kept the stereo just wish it would turn off the wires not connected as there isnt none thst colour to match i know nothing m8 i just wired it up lolalexperkins wrote:That doesnt look too good mate. Why are the orange and pink wires not connected to anything?
Re: Radio
Try swapping the red and yellow wires over - ie connect yellow to red, and red to yellow.
davemillson1212
- Drives: 2003 1.2
Re: Radio
Il give it a try later just hope it dont blow il let you know cheersalexperkins wrote:Try swapping the red and yellow wires over - ie connect yellow to red, and red to yellow.
davemillson1212
- Drives: 2003 1.2
Re: Radio
Trued what u said now the radio only comes on when the key is in and theres no clock showing when off where as before it wouldnt switch off and the clock stayed on so hoping this has done it il know later when i finish work if my battery deaddavemillson1212 wrote:Il give it a try later just hope it dont blow il let you know cheersalexperkins wrote:Try swapping the red and yellow wires over - ie connect yellow to red, and red to yellow.
Re: Radio
Thats working as it should now
davemillson1212
- Drives: 2003 1.2
Re: Radio
Thanks a lot just hope my battery not dead when i finish work ha haalexperkins wrote:Thats working as it should now
davemillson1212
- Drives: 2003 1.2
Re: Radio
Parked my car up friday night gone to start it up this morning and the batterys dead so the radio still causing me problems [emoji852]alexperkins wrote:Thats working as it should now
