Gearbox/driveshaft oil seal questions
rob090881
Drives: 9n 1.2
Post by rob090881 »
Hi all, I'm new on here. I've joined because my Mrs owns a 1.2 9N, which I am obviously responsible for maintaining, lol.
The polo very rarely spends any time above 40-50mph, because she only does short commutes. However, yesterday we went to Cheshire oaks outlet village, which is around 15-20 mins down a dual carriage way. The Mrs sat at 70mph all the way. When all of sudden it popped out of 5th and relined for a number of seconds. This unfortunately happened a few times, and struggled to go into 5th and 4th.
So today I checked the car over.
The gear linkages look ok, and so do the engine mounts. But I could be wrong. I then checked the gearbox oil. There was very little! Like an egg cup full?!?!?
So I filled it up, drove 7-8 mile, and it has leaked a fair bit. When I got home, there is lots of oil around the passenger side driveshaft.
So I'm guessing my driveshaft oil seal has gone? How hard is it to change, and how long should it take?
Should I be looking for anything else?
Here is a photo of the area in question. Does that driveshaft look OK? The car is parked on a slight hill with the wheel straight, but that joint looks a bit disjointed, or am I being paranoid?
Rob Image
Sent from my F8331 using Tapatalk
Re: Gearbox/driveshaft oil seal questions
I'd say that driveshaft oil seal has failed.
Its a bit of an evil job. I would probably entrust it to a local independent garage if you havent done one before. Driveshaft has to come off, then the driveshaft cup has to be pulled out, then seal out and reverse. Not a 5 minute task.
I hope that it is only an oil seal that has failed, I tend to get very negative about the root cause when I see oil leaking out of a shaft housing, and assume the worst, ie worn bearings causing the oil seal to wear and start leaking, I hope that in your case I am wrong!
rob090881
Drives: 9n 1.2
Post by rob090881 »
If there is something more severe wrong, is it usually obvious?
I'm happy to do the work myself. From what I've read, I should allow 2-3 hours.
Should I be removing the driveshaft from the hub, or is that not necessary? If I do, what size is the hub nut? Do I need a new one? I've not even had the wheels off this car yet, so im not entirely sure what to expect yet
http://workshop-manuals.com/volkswagen/ ... e/removal/
You dont need to remove the driveshaft from the hub. Only from the gearbox.
Youll need an M8 triplesquare tool to undo the driveshaft bolts.
rob090881
Drives: 9n 1.2
Post by rob090881 »
M8 splined tool? Is that the same as a Torxs bit?
No, very different. Torx is a star.
Correct term is triplesquare
rob090881
Drives: 9n 1.2
Post by rob090881 »
alexperkins wrote:No, very different. Torx is a star.
Thanks for that. Another excuse to add to my tool collection :)
bvs
Drives: 02 1.4s 16v
Post by bvs »
A 'Spline' drive set will be a useful addition to your tool collection Rob,I was lucky the other week whilst replacing a door lock module - I was using an online guide as a partial reference to help me and the writer had posted that the 2 largeish bolts on the actual lock body were torx - but they were actually spline drive - boy was I glad I had a multi bit set :mrgreen: (sunday afternoon LOL).
Now thanks to Alex I know the correct name for them :mrgreen:
Good luck with the seal etc btw
rgds baz
I know people that have tried to force torx into spline. I don’t need to tell you what happened :lol:
Needless to say, many swear words and hours of work later they were back to where they would’ve been if the used the correct tool
rob090881
Drives: 9n 1.2
Post by rob090881 »
So I haven't used my M8 splined tool yet. The shaft has pulled out without using it. Should I be worried?
Admittedly there is not a lot of room.
I'm guessing that is the seal I'm trying to replace at the front? Any suggestions on how to get it out without a puller or slide hammer/mallet? No oil leaked out, so I'm guessing it all leaked out again?!?!? Image
That’s very concerning. The driveshaft flange has completely detached from the gearbox. It’s meant to be bolted in!!!
Yes the seal at the front is what you are meant to be replacing. I think you’ll need a new driveshaft flange and new center bolt to go with it
The M8 spline tool is to undo the 8 bolts that hold the driveshaft onto the flange you can see in the photo.
rob090881
Drives: 9n 1.2
Post by rob090881 »
So would I be right in thinking that the seal might be OK, the problem is that the shaft has been allowed to retract enough to let the oil out? I can feel the end of a bolt sticking out of the coupling, so at least I have that!
The question you have to ask is how on earth has that come undone. The seal is likely damaged due to it not being tightened down properly
There’s also parts missing now. A shim, a special spring and a few washers. Do you want a copy of the diagram?
rob090881
Drives: 9n 1.2
Post by rob090881 »
I think they are still there. Once it's off, I'll take a pic of what I have
