Losing coolant....on and off
fangok
Drives: polo6n2
Post by fangok »
Hi
My polo from 99 has been using coolant continually for 2 years now, but recently it started leaving a pool of water (for it doesn't smell or look like coolant) on the driveway. I had to top the overflow up with a litre of water the other day but now it seems to be losing just a little coolant. What could this on-off leakage be due to ?
Re: Losing coolant....on and off
Could be a number of things. Split radiator, thermostat housing, leaking hose
Coolant is bright pink or bright green depending on what’s in your car so you should be able to trace where it’s coming from
