new springs results in uneven ride height
nofeeling
Post by nofeeling »
Just fitted 2 front springs ,drop links and a top mount bearing o/s .
Car is def about 10 mm lower on drivers side .
I know the new springs need to settle but I`m thinking could low tyre pressures be the cause .
ps , far too cold to check pressures at the minute .
Re: new springs results in uneven ride height
Are the springs seated properly in the strut and top mount?
nofeeling
Post by nofeeling »
Yes,both seated at bottom ,end of pigtail in position,top ,they just sit under mount .
Hopefully a week or two driving will help them settle .
