Wipers not turning off
Hi , my polo seems to have devolved a fault , the wipers do not switch off completely dispite the stalk stalk being in the off position . When in off position wipers are still on intermittent mode and only go off when ignition is off . I’ve found the fuse and bodged it by putting in a switch , but obviously this is a temporary fix ,can any one else give me any advice on a fix for this , ie is it stalk or relay . Thanks
Re: Wipers not turning off
Do the wipers run in intermittent mode when in the intermittent position?
blown fuse could point at a fault in the electrical circuit, short circuit. maybe the stalk? difficult to say.
i don't think the relay, since a stuck relay would not show intermittent but full speed wipers.
i'd have a look at the wiring to/from the stalk and the stalk itself.
That’s a fault with the stalk which needs replacing.
Yes all modes on stalk work except offalexperkins wrote: Wed Jan 03, 2018 5:35 pm Do the wipers run in intermittent mode when in the intermittent position?
All wires look fine , I Think I’ll try stalk , thanksiichel wrote: Wed Jan 03, 2018 7:22 pm blown fuse could point at a fault in the electrical circuit, short circuit. maybe the stalk? difficult to say.
I think I’ll replace stalk , thanks
Can’t find part number , I’ve found this on eBay looks correct
https://www.ebay.co.uk/itm/2014-VW-POLO ... Sw5cRZJtXz
Would this fit ?
Would this fit ?
Please show us a picture of your current configuration
You indicate that your car is a 2015 Polo, is that true, if so it should still be under warranty?
As rum says, this will be covered under warranty if your car is under 3 years old.
Didn’t even think about warranty! I’ve phoned them they are gonna have it in to sort it, I hope ! Excellent thanks I’ll let you know how it goesRUM4MO wrote: Thu Jan 04, 2018 9:35 am You indicate that your car is a 2015 Polo, is that true, if so it should still be under warranty?
I had the same problem with mine, took it to the dealers and they changed the indicator and wiper stalks under warranty. Been fine ever since.
I took the car to Volkswagen Bath for inspection under warranty. After inspection they concluded that the wipers were on intermittent mode and they switched them off !
I said don’t you think we would have tried that . Picked the car up wipers still on !!!! It’s back in today , hopefully for them to fix and replace stalk , dumbasses !
LOL
LOL
LOL
That is absolutely hilarious. Muppets....
LOL
LOL
