brake pads for blue gt
lynsmac83
Drives: Blue GT
Post by lynsmac83 »
hey guys,
I'm lookin for which size of pads will fit my 2014 blue gt.
cheers
lynsey
PoloBlueGT
Drives: Landrover Freelander
Re: brake pads for blue gt
Post by PoloBlueGT »
If you go on to ECP and put in your reg it will bring them
up there they are 288mm not the larger 312mm. Tears are 232mm if you require those.
lynsmac83
Drives: Blue GT
Post by lynsmac83 »
its pads as opposed to discs I'm after as sorted for them
gives two different sizes of pads as well
in the front you'll need the pads for 288/312mm rotors (the pads have the same size). in the rear it's one size fits all for the polo 6r.
lynsmac83
Drives: Blue GT
Post by lynsmac83 »
would the pads have the same PR code as the discs?
I would think so yes.
I can only find one specific group of pads for your car, strange that you are finding a size option!
lynsmac83
Drives: Blue GT
Post by lynsmac83 »
what pads did you find? i search for mine on eurocarparts!
That is what I was casually doing, seeing as you had reported having problems, I just inputted a 2014 VW Polo with 1.4 petrol engine - which brought up 256, 288 and 312 options, but as it seems that your car will only have the 288 front discs, there was only a few brands shown all with the same size of pads.
I do not need to replace my wife's August 2015 Polo 1.2TSI 110PS SEL pads, but when I do need to replace them I'd probably stick with TMD Friction products, which in a German built car should mean Pagid or Textar, I'm not sure if buying ATE pads makes better sense even although the front callipers are Teves (Alfred Teves = ATE), I've forgotten what brands are fitted to the front brakes of that in the factory, I say "brands" as normally you can make out the pad manufacturer's brand then another brand is often printed on along with maybe the official VW Group part numbers.
Edit:- my wife's Polo was built in South Africa as it is a 5 door car for RHD market, the factory fitted front pads are Jurid!
Another Edit:- I've just discovered that "Jurid by Honeywell" is a Federal Mogul group company if that means anything, I think that VW Group now use window wiper systems that in the parts cats are listed as FM which is again probably Federal Mogul though I have not worked out which company it is that has now come under the Federal Mogul banner.
PoloBlueGT
Just thought I’d add on to this topic than start a new one. I have seen these and am wondering whether they would fit my Blue GT as they seem to fit every other polo.
https://m.ebay.co.uk/sch/i.html?_from=R ... 2986977689
RUM4MO wrote: Thu Jan 04, 2018 12:24 pm I've forgotten what brands are fitted to the front brakes of that in the factory
that will most likely be TRW
iichel wrote: Mon Jan 08, 2018 6:26 pm
TRW = Lucas FSIII, but I think that version of front calliper is now manufactured maybe in India by Mando, the Blue GT will have the higher powered version of front brakes which are ATE, ie Teves, so normally they would not have TRW or TMD Friction branded pads, as I said Jurid which is a FM group company.
PoloBlueGT
So has anyone any idea whether the Brembo discs and pads would be suitable for my Blue GT?
lynsmac83
Drives: Blue GT
Post by lynsmac83 »
hey,
that was the brand I ended up going for, awaiting them coming home
PoloBlueGT
Which ones did you end up going for?
