I changed a headlight bulb tonight and the black plastic retaining ring that holds the bulb in has broken. Done a bodged job for now but where can I buy another one as can't see on eBay? Can you buy this part at the main dealer or will the say it's all part of a new headlight unit only.
I've checked an on line copy of ETKA and there is nothing listed for that I'm afraid as as far as I can remember, that part should always remain fixed to the head light assembly. The only repair parts listed are for the positioning motor assembly and the head light assembly mounting brackets.
I was guessing that you were meaning the horrible bit that you rotate slightly to lock the bulb in place?
Edit:- I do remember removing one once by unscrewing the small screws that held it in place, if that was correct then if you managed to get a headlight, even damaged, from a scrappy, you could swop over that bulb locking assembly?
