Got a couple of tyres changed on the rear tonight I mentioned to the guy I was changing my disks and pads he said when I’m going to do the work make sure I take the hand brake cable of the Caliper put the new pads and disks on then ratchet the lever on the caliper till the piston pushes up to the pads is this right or do you just pump the brake pedal any advice would be good many thanks
Rear brakes
Re: Rear brakes
That’s a great way to destroy the handbrake mechanism
You fit the new pads, reassemble and reconnect the handbrake cable then press the brake pedal till it’s hard before going anywhere near the handbrake lever
Vasey
- Drives: Polo gt bluemotion
Re: Rear brakes
Well that’s what I thought alexperkins but the guy at the garage told me this so I thought I would ask on here first before I start the work thanks for your advice much appreciatedalexperkins wrote:That’s a great way to destroy the handbrake mechanism
Re: Rear brakes
The first thing rear brakes will provide a back up in case of a failure of the front brakes. Not only that in modern brake systems it is quite normal for the rear brakes of a vehicle. For more detail about quality and genuine auto parts contact apex auto parts
