Hi All,
I am looking to enable coolant and if possible oil temp within my MFD (i have vcds)
Does anyone know if this is possible and the relevant coding? The cluster is the usual mid-line FULL MFD.
Instrument Cluster - Enable Coolant/Oil Temp?
Re: Instrument Cluster - Enable Coolant/Oil Temp?
If it were possible with your Instrument Cluster it would be in the IC adaptation channels.
I'm afraid this isn't possible with VCDS, you'll need an MFA+ if you want oil temp.
