Instrument Cluster - Enable Coolant/Oil Temp?
Posted: Thu Feb 15, 2018 9:06 am
by matt-t
Hi All,
I am looking to enable coolant and if possible oil temp within my MFD (i have vcds)
Does anyone know if this is possible and the relevant coding? The cluster is the usual mid-line FULL MFD.
Re: Instrument Cluster - Enable Coolant/Oil Temp?
Posted: Thu Feb 15, 2018 9:31 am
by ciclo
If it were possible with your Instrument Cluster it would be in the IC adaptation channels.
Posted: Thu Feb 15, 2018 9:32 am
by iichel
I'm afraid this isn't possible with VCDS, you'll need an MFA+ if you want oil temp.
