Polo 6R steering wheel codes
redpolo6r
Drives: @redpolo6r
Post by redpolo6r »
Hello, can someone please tell me part numbres of steering wheels for polo 6R??
I want code for:
polo 6r R-line steering wheel
polo 6r GTI steering wheel
polo 6r GT (BlueGT) steering wheel
All steering wheels with MF and with/without paddels
cheba
Drives: Polo R WRC 2014
Re: Polo 6R steering wheel codes
Post by cheba »
If you want part numbers you will also need to specify at least whether you want a wheel with DSG paddles or not, and if you want a multifunction steering wheel or not.
redpolo6r
Drives: @redpolo6r
Post by redpolo6r »
edited post :)
cheba
Post by cheba »
So I tried to compile a list of numbers by studying an ETKA database online. I am not 100% sure about all the numbers, so no guarantees. If someone notices an error, feel free to correct me.
6R GTI:
-With DSG paddles and with MFSW: 5K0419091AG
-With DSG paddles and without MFSW: 5K0419091AE
The 6R GTI was only available with DSG, I don't think it was ever made without paddles. But the part numbers for DSG paddle wheels are the same as for the Golf mk6, so we can borrow the numbers for non-paddle wheels from the Golf also:
-Without DSG paddles and with MFSW: 5K0419091AF
-Without DSG paddles and without MFSW: 5K0419091AD
6R BlueGT (These are a bit tricky since I couldn't find reference pictures to confirm the numbers):
-With DSG paddles and with MFSW: 6R0419091P
-With DSG paddles and without MFSW: 6R0419091N
-Without DSG paddles and with MFSW: 6R0419091M
-Without DSG paddles and without MFSW: 6R0419091L
6R R-Line (These are also tricky for the same reasons as the BlueGT wheels. Also only the "P" variant was listed under the Polo 6R, so I had to borrow the other numbers from the Golf mk6 part list):
-With DSG paddles and with MFSW: 1K8419091AC
-With DSG paddles and without MFSW: 1K8419091S
-Without DSG paddles and with MFSW: 1K8419091AB
-Without DSG paddles and without MFSW: 1K8419091P
And as a bonus, 6R R WRC:
-Without DSG paddles and with MFSW: 6R0419091S
redpolo6r
Drives: @redpolo6r
Post by redpolo6r »
Wow :shock:
Thank you :)
So golf mk6 gti steering wheel will perfect fit to polo 6r, right?
cheba
Post by cheba »
Well, the 6R Polo GTI with DSG paddles uses the same part number as the Golf GTI mk6 with DSG paddles after November 2010 so that should be a perfect fit (Golf GTI mk6 before November 2010 had a different part number, I don't know if it will fit).
It seems 6R Polo GTI wasn't made without DSG paddles, but it is my guess that a wheel without DSG paddles from a Golf GTI mk6 would be a direct fit on a manual 6R.
Christian_13
Drives: Polo 6R Highline 1.2 TSI 6-Gear
Post by Christian_13 »
Can i use the old airbag unit vom the standard 6R-steering wheel in the GT-Steering wheels?
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
For my Polo 6R 1.2 TSI 77KW 7DSG with 6R0937087R BCM --- Steering wheel with paddle shifter -- 6C0419091H works without any issues.
It has red backlight.
My car came with 6C0419091E (Without Paddles) so I used same airbag without any issues.
You can check -- viewtopic.php?p=523324#p523324
and
viewtopic.php?p=567244#p567244
if this cab help.
