Static Cornering Fog Lights - Mk5 2010
BenJD_177
Drives: Volkswagen Polo Mk5 59(2010)
Post by BenJD_177 »
Hey all!
Firstly; I'm new to the forum so please let me know if I'm in the wrong/right place!
Secondly; I have a bit of a strange problem with my Polo that I can't seem to find anywhere else, so I was hoping someone here might know how to help...
My car has static cornering fog lights that come on when you turn the wheel as intended...except for the fact that when you turn left, the right fog comes on; and (you guessed it) when you turn right, the left light comes on!
I have no idea whether this is a coding issue, or just a case of being plugged in the wrong way round, so any thoughts/suggestions are welcome!
Thanks in advance :D
Re: Static Cornering Fog Lights - Mk5 2010
It's plugged the wrong way around. You'll need to remove two wires from the so called bcm and swap them over. That's the ideal solution.
BenJD_177
Post by BenJD_177 »
Hello!
Thanks for the response, any idea how to access the BCM? And also any idea which wires they would be?
Sorry, I'm a noob!
Thanks! :lol:
Welcome!
White connector
9 and 10 . Interchange them.
:lol:
_______________
Edit
https://www.ebay.co.uk/sch/i.html?_from ... ol&_sop=15
....Image
BenJD_177
Post by BenJD_177 »
Thanks for the welcome, Ciclo!
Ah ok, so I remove the white connector and swap terminal 9 & 10?
Presumably that eBay link is the tool I’ll need to do so?
Thanks! :D
________________
Edit: should I disconnect the negative from the battery before I do this?
yes, yes, light switch in 0 position.
BenJD_177
Post by BenJD_177 »
Just got round to doing it, it worked PERFECTLY! Thank you SO much :lol: I managed to do it without the tool as well which saved a few quid and waiting for delivery! You absolute hero, thank you! :D :D :D
LOL! ... Thanks for reporting. :wink:
BenJD_177
Post by BenJD_177 »
:lol: :lol: :lol:
Perfectly and works like a charm are two terms that will haunt me all my life here... hahaha! Image
left-right, right-left :lol:
BenJD_177
Post by BenJD_177 »
Hahaha well there are far worse things to be haunted by! Your help is greatly appreciated! :lol:
