Hi guys,
I need your help!
I'm trying to install electric, heated and folding outside rear view mirrors on my car which currently has only fully manual ones (I know here in India these guys have really skimped on necessary elements!)
I have sourced parts for the wing mirrors and the switch that's needed (not bought yet) and I also have a BCM PQ25 module ending with 87 on which I've enabled cruise control looking at the awesome guides here on Ukpolos!
I wanted to know how I could go about this with respect to the wiring and getting this to work. Will need some direction to do this!
My car is a Skoda Fabia 1.2 Tdi 2011 facelift (5J)
Thanks and cheers in advance!
Aayush
Skoda Fabia - electric windows retrofit - Help!
aayushnair
- Drives: Skoda Fabia 1.2 tdi
Re: Skoda Fabia - electric windows retrofit - Help!
PM Ciclo - he can help
VCDS autoscan and reference/part number of the parts purchased so far.
In this way I can provide you the diagrams to do this job.
aayushnair
Hi Ciclo,
Here’s the information -
BCM - 6R7937087M
Wing mirror - 5J0857522M
Wing mirror switch - J1959565
5Chassis Type: 5J (6N0)
Scan: 01 09 15 17 19 25 44
VIN: TMBFKC5J1BG*******
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 R HW: 03P 906 021 R
Component: R3 1.2 DCM3.7 H04 9312
Revision: 13001001 Serial number:
Coding: 00110012032100000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TDI03103P906021R 001009
ROD: EV_ECM12TDI03103P906021AC.rod
VCID: 377DCD578EB85FA6659-8062
1 Fault Found:
13976 - No Communication with Instrument Cluster
U0155 00 [063] - -
Confirmed - Not Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 67117 km
Date: 2055.14.03
Time: 00:19:28
Readiness: 1010 1000
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
Component: PQ25 BCM H28 0555
Revision: -1------ Serial number: --------------
Coding: 7C980B9808D30748002000003C2890000080000F60000000000000000000
Shop #: WSC 12345 123 12345
VCID: 4E9388B31922FE6E56F-801B
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3210
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3210
Coding: 020000
1 Fault Found:
03579 - Terminal 30 for Rear Window Heating
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 71184 km
Time Indication: 0
Date: 2055.14.03
Time: 00:19:23
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10AirbagR03 H09 0020
Revision: -------- Serial number: 003GW0037KRM
Coding: 003033
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4999BBAFE84CD95603D-801C
Address 17: Instruments (J285) Labels: None
Part No SW: 5JF 920 800 A HW: 5JF 920 800 A
Component: KOMBI X12 0009
Coding: 720800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04061
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
VCID: 3979CB6FB8AC49D693D-806C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 087 M
Component: GW-K-CAN TP20 H28 0555
Revision: -1------
Coding: 032300
VCID: F0EFB64B2356489EE43-80A5
1 Fault Found:
01336 - Data Bus for Comfort System
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 71184 km
Time Indication: 0
Date: 2055.14.03
Time: 00:19:23
Address 25: Immobilizer (J334) Labels: None
Component: IMMO X12 0009
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03007
ROD: EV_Immo_UDS_VDD_RM09_SK25.rod
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-44.clb
Part No SW: 6RF 909 144 H HW: 6RF 909 144 G
Component: EPS_ECU H25 0321
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 004004
ROD: EV_SteerAssisUDSNSK.rod
VCID: 51A993CF001CE1964BD-8004
End ---------------------------------------------------------------------
VCDS - it’s an old scan; nothing has changed since
Thanks a lot!
Cheers!
BCM - 6R7937087M
1 Fault Found:
U0155 00 [063] - -
Fault Priority: 2
Fault Frequency: 4
Mileage: 67117 km
Date: 2055.14.03
Time: 00:19:28
Coding: 030000
Coding: 020000
1 Fault Found:
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 71184 km
Time Indication: 0
Date: 2055.14.03
Time: 00:19:23
Coding: 003033
Coding: 720800
Revision: -1------
Coding: 032300
1 Fault Found:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 71184 km
Time Indication: 0
Date: 2055.14.03
Time: 00:19:23
Serial number:
Coding: 0000
Thanks a lot!
Cheers!
I don't have Skoda diagrams, but in your inbox you have a link to the diagrams belonging to POLO 6R (2010-2014 Europe) in a PDF file. Download them.
Within them you should look for Electrically adjustable and heated exterior mirror, .. and according to the points/connection pins adapt the wiring to your Fabia. (Fusebox- BCM - WRMs - Mirrors Switch)
Coding with VCDS is simple once you have finished the installation, I will help you with this if you need.
aayushnair
Thanks so much Ciclo! Will have a look and adapt accordingly!
As always you seriously try your best to help out!
Will get in touch once completed!
Cheers man!
Cheers man!
