Can any one help and tell me what this is in my fuse board click the link
https://ibb.co/kovDSS
HELP !! Whats this in my fuse board?
Dink
- Drives: 2015 GTI
Re: HELP !! Whats this in my fuse board?
a death trap?
joking aside do you have a dash cam/sat nav/bluetooth phone adapter permanently fixed some where?
it's probably the supply for that.
Badly executed power tap from fuse box... Would suggest to get a proper piggyback fuse or insert properly from rear. This is crap
Thanks for the help!! Will look at finding one todayiichel wrote: Sat Apr 21, 2018 10:52 am Badly executed power tap from fuse box... Would suggest to get a proper piggyback fuse or insert properly from rear. This is crap![]()
Dink
- Drives: 2015 GTI
just make sure you fit a suitable rated fuse on to whatever this wire is going to.
How can i tell what amp fuse is needed ?Dink wrote: Sat Apr 21, 2018 11:50 am just make sure you fit a suitable rated fuse on to whatever this wire is going to.
Dink
- Drives: 2015 GTI
i doubt you would need anything bigger than a 5A fuse but i don't know what the wire is for.
Its a hands free tpkDink wrote: Sat Apr 21, 2018 6:20 pm i doubt you would need anything bigger than a 5A fuse but i don't know what the wire is for.
Dink
- Drives: 2015 GTI
yeah 5A fuse will be more than enough
DatPoloGuy
- Drives: 6n2 2000
Someone's clearly just had to bodge that in there[emoji23]Finlay6r wrote:Can any one help and tell me what this is in my fuse board click the link
Yes, that is as good as it looks, very nasty!iichel wrote: Sat Apr 21, 2018 10:52 am Badly executed power tap from fuse box... Would suggest to get a proper piggyback fuse or insert properly from rear. This is crap![]()
Edit:- alternatively, a professional has fitted some aftermarket equipment.
