Can anyone recommend who to change G263 Evap Outlet Temp Sender
sharkman07
Drives: 1.4tdi 9N
Post by sharkman07 »
I know I'm going to bugger something else up if I mess around with removing bits of the dash, can anyone recommend someone to do this? Beds/Herts/Bucks/London.
Thank you
sharkman07
Drives: 1.4tdi 9N
Re: Can anyone recommend who to change G263 Evap Outlet Temp Sender
Hmmm maybe its a bit quiet here.. :?:
Has anyone changed it that can offer advice please? I can find an online guide for the Audi A2 but not for Polo. I may have a crack at it myself. Thank you
I know nothing about VW Group’s DERV engines, but this is not a topic that I’ve noticed in the past, so maybe that is why no one is handing out advice.
If you have A2 info for same engine that should be a good starting point though should be better access in 9N Polo than A2.
sharkman07
Drives: 1.4tdi 9N
Thank you, yes the A2 appears a different layout and I'm looking for instructions how to access it on a 9N. I appreciate the reply.
