Fuse box diagram
lottie_ellis
Drives: 6n2 gti 1.6 16v 2001
Fuse box diagram
Post by lottie_ellis »
Hey all.. anyone have any idea where I can find the fuse diagram for the 1.6? I’ve looked everywhere but can’t find it [emoji854]
Re: Fuse box diagram
SBF1- 10A- Oxygen Sensor Heater
SBF2- 5A- Number Plate Light
SBF3- 10A- Fuel Injectors
SBF4- 5A- LH Sidelight
SBF5- 5A- RH Sidelight
SBF6- 15A- Rear Window Wiper
SBF7- 7.5A- Direction Indicators
SBF8- 5A- ABS With EDL/ESP
SBF9- 5A- Headlight Levelling
SBF10- 7.5A- Interior Lighting, Glovebox Light, Vanity Mirror Light, Luggage Compartment Light
SBF11- 5A- Diagnostic Connector, Instrument Cluster, Air Conditioning
SBF12- 10A- RH Headlight Main Beam and Warning Light
SBF13- 10A- LH Headlight Main Beam
SBF14- 10A- Hazard Warning Lights
SBF15- 10A- Stop (brake) Lights
SBF16- 5A- Ignition Switch ‘S’ Contact
 SBF17- N/A- None Applicable/ Not Used
SBF18- 5A- Heated Mirrors
SBF19- 15A- Horn
SBF20- N/A- None Applicable/ Not Used
SBF21- N/A- None Applicable/ Not Used
SBF22- 15A- Alarm System
SBF23- 5A- EGR, Air Mass Meter, Additional Heater Relay, Glow Plug Relay
SBF24- 5A- Clutch Pedal Switch (Diesel)
SBF25- 5A- Selector Lever Switch (Automatic Transmission)
SBF26- 7.5A- Air Conditioning, Central Locking, Electric Windows, Electric Mirrors, Navigation System
SBF27- 5A- Instrument Cluster
SBF28- 5A- Speedometer Sensor Unit, Immobiliser
SBF29- 7.5A- Reversing Lights, Heated Washer Jets, Headlight Levelling
SBF30- 5A- EGR Valve, Charcoal Filter Solenoid
SBF31- 10A- Engine Management
SBF32- 5A- Fuel Shutoff Control Unit (Diesel)
SBF33- N/A- None Applicable/ Not Used
SBF34- 10A- Ignition Transformer
MBF35- 25A- Sunroof
MBF36- 15A- Engine Management
MBF37- 15A- Engine Management
MBF38- 25A- Drivers Electric Window (RH Presumably)
MBF39- 25A- Passengers Electric Window (LH Presumably)
MBF40- 15A- Fuel Pump
MBF41- 15A- Central Locking, Alarm System
MBF42- 15A- Radio, Navigation
MBF43- 15A- Front and Rear Foglights
MBF44- 15A- LH Headlight- Dipped Beam
MBF45- 15A- RH Headlight- Dipped Beam
MBF46- 15A- Cigar Lighter
MBF47- 20A- Headlight Washer
MBF48- 20A- Heated Rear Window
MBF49- 25A- Heater Blower Motor
MBF50- 15A- Front Wash/ Wipe
MBF51- 15A- Heated Seats
KEY- SBF- Small Blade Fuse, approx. 10mm across
MBF- Medium Blade Fuse, approx. 15mm across
SBF1- The number is the fuse board location number. So this means Small Blade Fuse number 1 in this example.
15A- The number represents the rating of fuse, so in this example it’s 15 Amps. The A stands for Amps, or Amperes if you prefer!
lottie_ellis
alexperkins wrote:SBF1- 10A- Oxygen Sensor Heater
SBF19- 15A- Horn
MBF35- 25A- Sunroof
Thank you! x
