Blue Gt Cold air intake
Does anyone know a good cold air intake for blue gt which is more or less a straight fit?
Ricmondo
- Drives: Polo Blue GT
Re: Blue Gt Cold air intake
Can you explain what you mean by a cold air intake please, it will help responders to give a helpful answer.
I am assuming you are not referring to those intake kits that draw hot air from under the bonnet.
Just an upgrade from the normal panel filter what ever would be best really.
The oem intake is already very good. Why would you replace it?
I was just wondering if there was anything better really I will probably just keep it the way it is then.
If you want more noise of whatever, you could have a look at an open air filter. But performance wise, the stock filter is a really good choice.
I already upgraded to the k&n panel filter anyway so I think I will just keep that.
