RNS 510 P speakers error.
Discuss In Car Entertainment
martijnoss
Drives: polo 6r
Post by martijnoss »
Hello
I have a custom entertaiment in my car with own amplifiers and speakers.
Vcds there is an error in the speakers.
Is there a way to exclude the errors in the radio with vcds.
Thanks in advanche
Edit: i set the rns coding. byte 4 to inactive but the eroors keep coming back.
Wednesday,06,June,2018,19:00:59:18846
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ6RZCY018898   License Plate: STORING LAP
Mileage: 211690km-131538mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6RZCY018898   Mileage: 211690km-131538miles
37-Navigation -- Status: Malfunction 0010
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
   Component: RNS-MID       H10 5238
   Revision: AB001001    Serial number: VWZ6Z7J2224002
   Coding: 00010400000000000000
   Shop #: WSC 12345 123 12345
   VCID: 3B22C7DD1361393F645-806E
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
4 Faults Found:
00859 - Line-Output; Front Right
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
00823 - Line-Output; Front Left
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
00869 - Line Output; Rear Right
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
00860 - Line-Output; Rear Left
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
4 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 211680 km
                    Time Indication: 0
Re: RNS 510 P speakers error.
code rns correctly
martijnoss
Drives: polo 6r
iichel wrote: Mon Jun 11, 2018 9:22 pm code rns correctly
Oke, i did something wrong i geuss otherwise you wont say that.
Can you help me a little bit in the direction what i should code.
I thought i install the radio and put the pin of the radio and it will works correctly.
the values of the speakers is set correct, the speaker warning not active.(i dont know the correct name in the line now i am laying on the couch)
