Number plate LEDs
Robby71
Drives: 2019 Golf R-Line EVO
Number plate LEDs
Post by Robby71 »
Ok so i've now tried 4 pairs of LEDs for the number plate bulbs and even though all state they are canbus compatible they have all put on the dash warning to check number plate bulbs :(
Does anyone know which bulbs do not bring on the dash warning as i'm getting fed up ordering, waiting a week for delivery and finding the new bulbs are just as bad :?:
Tombirch95
Drives: 2011 Polo Match 1.2 TDI
Re: Number plate LEDs
Post by Tombirch95 »
Robby71 wrote:Ok so i've now tried 4 pairs of LEDs for the number plate bulbs and even though all state they are canbus compatible they have all put on the dash warning to check number plate bulbs :(
I bought a pair of SMD bulbs from amazon that stated they where canbus compatible, in the end I just disabled the warning using VCDS just make sure to check the lights every now and then, not that you can miss them [emoji23]
EdgardoRodriguez
Drives: other
Post by EdgardoRodriguez »
Canbus LED lights is a missconception, they have no can capabilities. They use a resistor in series just to emulate the current drawn from a regular incandescent bulb. So you will be using or precisely wasting current and generating hear for nothing..
But ok, I know with vcds (because I did it with a pair of osram led bulbs) that you can tell the BCM module if plate lights are regular or led style.
From my notes the following should solve your issue:
Byte 27-bit 0 -> checked
Enviado desde mi iPhone utilizando Tapatalk
Byte11 Bit7 -->1
Robby71
Post by Robby71 »
weird thing happening now - same led bulbs in and no warnings on dash anymore :shock:
FAYBAE
Drives: 6C POLO GT DSG
Post by FAYBAE »
I'd go OEM plate bulbs, the aftermarket ones are stupid bright so much so it kind of obscures the numberplate ha! I've had these in the past and i'd never buy another aftermarket pair. Never had issues with CANBUS tho. :D
