Retrofitting folding side mirrors
Alvin1001
Drives: vento
Post by Alvin1001 »
Hi guys, I own a Vento that does not come standard with side folding mirrors .
Thinking of retrofitting into my car, has anybody done it before?
I have bought the new mirror with folding (8 pins) and the new folding switch .
My door module part number is 6R0 959 802 AL ( driver side), 6R0 959 801 AH (passenger side).
So far I have connected a wire to my folding switch(pin8) to WRM (pin 12) , and the other 2 wires to t16g/14 and t16g/15.
However, nothing happens when I twist the switch. Tried recording my module to 010002, 0100B3, 0100B1 but code rejected.
Re: Retrofitting folding side mirrors
It's highly likely that the software (SW 5xxx or 5540) of your window regulator motor - door module - doesn't support the folding mirror function.
What's the model year of your Vento? (letter, tenth digit of the VIN)
Alvin1001
Drives: vento
Post by Alvin1001 »
ciclo wrote:It's highly likely that the software (SW 5xxx or 5540) of your window regulator motor - door module - doesn't support the folding mirror function.
Hi Ciclo, the 10th digit of my car is F. My car is manufactured in 2015
I'm afraid your WRMs don't support the mirror fold function.
Read the govindsharma's topic.
edit
4R3 comfort function .... for windows.
Alvin1001
Drives: vento
Post by Alvin1001 »
ciclo wrote:Image
edit
I see. So which version of regulator should I get? Any specific PR codes?
Alvin1001
Drives: vento
Post by Alvin1001 »
*Update*
Took the door module from a beetle, plugged into my car, mirror folds without any additional coding.
But the window does not roll all the way up as beetle has a frameless door.
Looks like I'll have to find a door module thats for polo or vento
At least we now know your wiring is all OK!
Beetle Bluemotion.
2013?
Alvin1001 wrote: Sat Jul 28, 2018 11:50 am Looks like I'll have to find a door module thats for polo or vento
Read govindsharma thread. :)
Alvin1001
Drives: vento
Post by Alvin1001 »
ciclo wrote:Beetle Bluemotion.
2013?
It's a 2012 beetle 2.0 with standard folding mirrors :)
Sure. Will do
Thanks Ciclo
Alattar26
Drives: Polo 3 door 2017
Post by Alattar26 »
Could you please give more explanation about the cabling done. I have a Polo i got the mirrors and everything however the switch to fold doesnt work and only the passenger side mirror fold. Please help with the driver side cabling needed.
renato_zg_
Drives: 6r 1.6
Post by renato_zg_ »
ciclo wrote: Sat Jul 28, 2018 5:47 am Image
what is this program ? 🙈
renato_zg_ wrote: Thu Apr 23, 2020 5:12 am
Ifinterface.com
DanielJackson
Drives: 1.2tsi 6c CBZB
Post by DanielJackson »
ciclo wrote:Image
edit
Hey ciclo I wonder if you can help me I reteo fitted folding mirrors following your guide the mirrors successfully fold on the mirror switch but not with locking and unlocking the car ImageImageImageImageImage
Sent from my SM-G955F using Tapatalk
Byte02 Bit1 enabled, both WRMs.
Redo the comfort function with the window switches, in both doors/windows.
https://www.uk-polos.net/viewtopic.php? ... 30#p481352
DanielJackson
ciclo wrote:Byte02 Bit1 enabled, both WRMs.
I have changed the coding on both WRM's to enable byte02 and bit1 with no success of folding the mirrors when locking and unlocking ImageImage
