I am not sure what PSI I should be filling my tyres too
It has 2 stick men with a bag twice, one has a picture of an open book with a ' i ' inside and this is a lower PSI, the other does not have this book ' i ' inside and is higher PSI
44/41 and 39/36
Whats the difference and which should it be? Thanks for the confusion VW
Tyre Pressure for 2017 Blue GT ?
Re: Tyre Pressure for 2017 Blue GT ?
The book symbol with the ‘i’ in it is referring you to information on tyre pressures in your owner’s manual - specifically the ‘comfort’ tyre pressure setting. Not all models of Polo have a comfort tyre pressure setting (my GTI doesn’t), the intention being that if you find the normal tyre pressures give too firm a ride, then reducing the pressure to the comfort setting will give a more comfortable, compliant ride.
In my manual, the relevant pages are 233 and 234.
OK Thanks
