Multiple Malfunctions?
Just upgraded the BCM from 6R0937085E to 6R0937087R and I did an autoscan on VCDS. I got this:
Wednesday,08,August,2018,21:04:07:39744
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ6RZCU015643 License Plate:
Mileage: 81180km-50442mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCU015643 Mileage: 81180km-50442miles
04-Steering Angle -- Status: Sporadic communication error 1000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CGPB) Labels: 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 8949
Revision: -------- Serial number:
Coding: 00110016000400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM1M2PI02103E906019M 001007
ROD: N/A
VCID: 2E54D5FA718C05321E-807A
No ASAM data for: "EV_ECM1M2PI02103E906019M" (VW25)
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3216E00B7C42B24E684D400801100
Shop #: WSC 31414 790 31414
VCID: 071A405EB2B6747AFD-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 F HW: 6R0 820 045 F
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 316ECE8668B21ACA03-8064
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 64
Reset counter: 234
Mileage: 73423 km
Time Indication: 0
Date: 2012.03.10
Time: 00:00:00
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 R HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0424
Revision: BF034001 Serial number: 0681 182140516
Coding: 7CB02BBF08A10048002008002D2B0C900040410F60060000200000000000
Shop #: WSC 00049 770 00139
VCID: 4C90BF72EF50572210-8018
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 1611
Serial number: KU0KU005051100015130
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001071100011937
Coding: 08BC30
8 Faults Found:
03432 - Activation of Right Parking Light
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:05
03302 - Response Closing Status of Passenger's Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:04:52
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 202
Mileage: 81181 km
Time Indication: 0
Date: 2012.12.29
Time: 00:00:02
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:08:23
01117 - Generator Terminal DF Load Signal
Fault Priority: 3
Fault Frequency: 3
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.09.11
Time: 00:07:28
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 81181 km
Time Indication: 0
Date: 2012.12.29
Time: 00:00:04
01332 - Door Control Module; Passenger Side (J387)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:05
03591 - Control Circuit for Horn
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 53044 km
Time Indication: 0
Date: 2013.09.11
Time: 17:24:32
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RYHRS
Coding: 003237
VCID: 4A9CB96AED24491222-801E
Serial number: 3575HRB405J0IRE26121
Serial number: 3585HRB405F0IRE2DPQA
Serial number: 3515RRB40550M38E1P71
Serial number: 3525RRB404R0LCOS3GVZ
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 960 G HW: 6R0 920 960 G
Component: KOMBI H03 0505
Coding: 440200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 397EF6A6B8C2D28ABB-806C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BF034001
Coding: 002300
VCID: 70E80B82A33853C24C-8024
3 Faults Found:
01336 - Company Data Bus for Comfort System
Fault Priority: 1
Fault Frequency: 9
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:02
00778 - Steering Angle Sensor (G85)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:01
03590 - Control Module for Multifunction Module
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 81181 km
Time Indication: 0
Date: 2012.12.29
Time: 00:00:04
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VD_DRM09 A03009
ROD: N/A
VCID: 6ADC19EA8DE4A91202-803E
No ASAM data for: "EV_Immo_UDS_VD_DRM09" (VW36 *)
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F6AC8FEEA860C3A15-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio 553 0555
Revision: R0553006 Serial number: VWZ5Z1L0550741
Coding: 0000020002
Shop #: WSC 00000 000 31414
VCID: 2A5CD9EA45646912C2-807E
End-------------------------(Elapsed Time: 02:23)--------------------------
This was the first time doing an autoscan so some of the faults could have already been there since I bought the car off the previous owner. Should I be worried?
www.Ross-Tech.com
ROD: N/A
Revision: --------
Revision: 0002S 02
1 Fault Found:
Fault Priority: 2
Fault Frequency: 64
Reset counter: 234
Mileage: 73423 km
Time Indication: 0
Date: 2012.03.10
Time: 00:00:00
Coding: 18BC30
Coding: 08BC30
8 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:05
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:04:52
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 202
Mileage: 81181 km
Time Indication: 0
Date: 2012.12.29
Time: 00:00:02
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:08:23
Fault Priority: 3
Fault Frequency: 3
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.09.11
Time: 00:07:28
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 81181 km
Time Indication: 0
Date: 2012.12.29
Time: 00:00:04
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:05
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 53044 km
Time Indication: 0
Date: 2013.09.11
Time: 17:24:32
Coding: 003237
Coding: 440200
Revision: BF034001
Coding: 002300
3 Faults Found:
Fault Priority: 1
Fault Frequency: 9
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:02
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 53045 km
Time Indication: 0
Date: 2013.10.16
Time: 00:00:01
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 81181 km
Time Indication: 0
Date: 2012.12.29
Time: 00:00:04
Serial number:
ROD: N/A
Coding: 11250
Shop #: WSC 31414
Coding: 0000020002
Re: Multiple Malfunctions?
Could you describe how you changed the BCM please? step by step?
I used this exact guideiichel wrote: Wed Aug 08, 2018 9:26 pm Could you describe how you changed the BCM please? step by step?
http://www.team-bhp.com/forum/diy-do-yo ... odule.html
I am sure I didn't mess with anything and I backed up original settings.
do you still have an autoscan with the original coding of your 085 BCM? because I have the idea you didn't copy BCM coding and CAN gateway installation list.
I'm suspecting you did a bad BCM swap, but that can be fixed.
I didn’t do an auto scan with my 085 BCM but I took screenshots of the installation list and copied down the coding. I successfully changed the installation list and coding back to the stock BCM after installing the 087 BCMiichel wrote: Thu Aug 09, 2018 8:48 am do you still have an autoscan with the original coding of your 085 BCM? because I have the idea you didn't copy BCM coding and CAN gateway installation list.
I still have power to the door and horn etc ?
can you clear all errors and see which ones come back?
Cleared all the fault codes and only HVAC one appears now after rescan. I know my AC system is faulty ... so the BCM replacement went ok?
I suppose so. Most errors were flagged as intermittent and they were not making a lot of sense to me.
If they dont re-appear, it seems like your BCM upgrade was successful.
Thanks very much!iichel wrote: Thu Aug 09, 2018 1:56 pm I suppose so. Most errors were flagged as intermittent and they were not making a lot of sense to me.
Also, is it hard to fit a wireless key remote system? My polo didn’t come with a wireless unlocking system
your new BCM supports remote key locking.
however, you'll probably have to replace your keys. This will probably require learning new keys to the immobiliser.
Is there a guide for this pls?iichel wrote: Thu Aug 09, 2018 2:30 pm your new BCM supports remote key locking.
Not that I'm aware of, sorry.
