hi, firstly I would like to say hello and apologize for my bad english
i have three problems
first. I have a parktronic at the front and back, but the RCD310 does not show me the front sensors (they work correctly)
Does anyone know where this option runs in VCDS or what could be the reason?
second
is there an inscription (rcd310) in French in order to be careful, I change it into another language?
third
vcds shows me the constant value of the oxygen probe, 0.505v. Is this correct? it should, after all, oscillate during acceleration
I do not have a probe error. What should the correct values be?
Thank you for your help
Paul!
6R - 1.6TDI 90HP / Oxygen probe, language RCD310
Re: 6R - 1.6TDI 90HP / Oxygen probe, language RCD310
Sorry I don't know any answers to your questions, but I'd hope that someone will eventually.
Your parking sensor problem, did that car come out of the factory with front and rear parking sensors fitted, or just rear parking sensors?
You do not know what/how much your RCD310 does in terms of showing the parking sensors, but, my Audi S4 came out of the factory with only rear parking sensors, and the only indication that I had was that they "beeped". Some years later, I fitted the correct wiring, sensors, 8 channel parking controller, extra buzzer and new switches, then reprogramed my car to allow me to have OPS which is Audi's name for Optical Parking System, which lets you know visually on the car's display, where any dangers are located.
So, using VCDS can you see that you have the correct parking controller for front and rear sensors and that it now coded correctly, you need to do the same for the MMI to allow the display of the parking sensors, ie OPS.
