Page 1 of 2
Polo 2015/16 Auto-dimming mirror - RLS - Long Coding
Posted: Thu Aug 30, 2018 12:54 pm
by TDITorque
Hello Folks!
I recently installed OEM Autodimming mirror and RLS on my Polo Highline 2015/16 model. It was a DIY and I did a perfect job installing new mirrors and brackets on existing windshield. I can post the entire steps if anyone is interested in it.
I took help of VW service guy to wire the pins into BCM (I have very little idea in wiring department). Auto-dimming mirror is working great.. however, Rain light sensor (RLS) is not working. VW service guy tried to enable RLS using scanner tool. In fact there is a fault code (01044 - Control Module Incorrectly Coded) coming ever since he did attempted the coding.
Questions-
1. Does my BCM support RLS for automatic wiper?
2. Is there any compatibility issue with RLS and BCM or Auto dimming mirror? below are the part numbers.
BCM - Part No SW: 6RU 937 086 M HW: 6RU 937 086
Rain-light sensor (RLS) - 5K7 955 559C
Autodimming Mirror - 3G0 857 511E SMA
Any help is much appreciated.
Re: Polo 2015/16 Auto-dimming mirror - RLS - Long Coding
Posted: Thu Aug 30, 2018 12:58 pm
by iichel
I'm gonna take an educated guess here and say the 086M BCM can't do RLS, you'll need an 087 BCM or higher to make it work.
Posted: Thu Aug 30, 2018 2:28 pm
by TDITorque
Thanks for quick reply! Is there any way to check what options are supported by my BCM?
Below is the VCDS scan report and RLS did show up in there. Does it mean RLS is supported? Any guess on fault -
Saturday,25,August,2018,15:52:32:00001
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXK1560XGT041844 License Plate:
Chassis Type: 60-VW25 (6RU)
Scan: 01 03 08 09 15 17 19 25 44
VIN: MEXK1560XGT041844 Mileage: 49020km-30459miles
Address 01: Engine (J623-CWXA) Labels: None
Part No SW: 03L 906 023 SL HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00110116032500080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM15TD0I2103L906023SL 001001
ROD: N/A
VCID: 020AB294950F10540E-8056
No ASAM data for: "EV_ECM15TD0I2103L906023SL" (VW25)
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2763412718C1061CE46D825518020000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_Brake1AB9S0BOSCH 003017
ROD: N/A
VCID: 0304B7908A15195C05-8056
No ASAM data for: "EV_Brake1AB9S0BOSCH" (VW25)
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41887D98D889CB4C57-8014
Component: BCM IM M+4 H40 0432
Revision: BY040001 Serial number: 0200 274150241
Coding: 3AB02BFF08A10000003800006C2B04900080414F608C0000200000000000
Shop #: WSC 02380 002 1048576
VCID: 6BD4FF308A85F11CDD-803E
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 140415 03 37 0059
Coding: 028877
Subsystem 2 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC Labels: 6R0-959-802.CLB
Component: ------------- 007 5551
Serial number: 13102670150723012728
Coding: 050000
Subsystem 3 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT Labels: 6R0-959-801.CLB
Serial number: 13102671150715110057
Coding: 050000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 1901509405801101AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13102580150708080029
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581150715130014
Coding: 020000
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 37
Reset counter: 255
Mileage: 47028 km
Time Indication: 0
Date: 2016.09.22
Time: 11:16:30
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW010V9FL
Coding: 003036
ASAM Dataset: EV_AirbaVW1B0PAVW250 A01001
ROD: N/A
VCID: 499865B8E8B9030C8F-801C
No ASAM data for: "EV_AirbaVW1B0PAVW250" (VW25)
Part No SW: 6RF 920 862 HW: 6RF 920 862
Component: KOMBI H01 0214
Coding: 1508000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 0918A5B8A839430C4F-805C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 H40 0432
Revision: BY040001
Coding: 002300
VCID: 1938F5F81099B38CFF-804C
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H01 0214
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710
ROD: N/A
VCID: 6ADAFA348D7FE814A6-803E
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
Address 44: Steering Assist (J500) Labels:. 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ASAM Dataset: EV_SteerSasisNSK 014008
ROD: N/A
VCID: 41887D98D089CB4C57-8014
No ASAM data for: "EV_SteerSasisNSK" (VW25)
End-------------------------(Elapsed Time: 02:05)--------------------------
Posted: Thu Aug 30, 2018 2:48 pm
by iichel
So I think I'll correct myself and say it is compatible, but the coding wasn't very successful. Perhaps this will work:
3AB02BFF08A10000013800006C2B26900080414F608C000020A000000000
This way, the RLS is installed (byte 8 to 01) and the rain sensor and automatic wipers are activated.
I suppose you could enable the light sensor function as well (byte 13 from 2B to AB), but I doubt it will add any functionality.
Posted: Thu Aug 30, 2018 3:05 pm
by TDITorque
Last time while enabling RLS using VCDS Long Code Helper, somehow long code got changed to B02B7F09A1000000380000642B04900080414F6080000020000000000000 and all body control electricals (horn, window up-downs, steering controls) stopped working. I am still puzzled as to how long code changed so drastically (I used long code helper and didn't tweak much).
When I tried restoring the older long code saved in earlier scan report, VCDS says Coding Accepted but the entered code was not reflecting. Do you know what could be the reason behind that? I do not want to get into same trouble again and want to take experts advise before reattempting it.
Many thanks for your prompt replies!
Posted: Thu Aug 30, 2018 3:21 pm
by iichel
Could you please try the coding I provided and tell the results?
Posted: Fri Aug 31, 2018 9:04 am
by TDITorque
I'm going to try it over the weekend.. will share the outcome.. fingers crossed!
Posted: Sun Sep 02, 2018 4:46 pm
by TDITorque
When I looked at VCDS today, long coding position that you suggested is different than what is shown by VCDS helper. RLS is at byte 4 position and byte 8 position shows error. Now, I'm confused and want your opinion before proceeding with making changes.
Scan report
Sunday,02,September,2018,19:14:19:00001
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: MEXK1560XGT041844 Mileage: 49260km-30608miles
ASAM Dataset: EV_ECM15TDI02103L906023SL 001001
ROD: EV_ECM15TDI02103L906023RS.rod
VCID: 020AB294950F105687-8056
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0304B7908A15195E8C-8056
Revision: V0000000
VCID: 41887D98D889CB4EDE-8014
Shop #: WSC 60425 002 1048576
VCID: 6BD4FF308A85F11E54-803E
Coding: 028877
Coding: 050000
Coding: 050000
Coding: 240000
Coding: 020000
Coding: 020000
1 Fault Found:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 49047 km
Time Indication: 0
Date: 2016.11.02
Time: 15:36:26
Coding: 003036
VCID: 499865B8E8B9030E06-801C
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Coding: 1508000000
VCID: 0918A5B8A839430EC6-805C
Revision: BY040001
Coding: 002300
VCID: 1938F5F81099B38E76-804C
Serial number:
VCID: 6ADAFA348D7FE8162F-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 41887D98D089CB4EDE-8014
End-------------------------(Elapsed Time: 02:01)--------------------------
here are the vcds helper screenshots.
Posted: Sun Sep 02, 2018 4:48 pm
by TDITorque
Posted: Mon Sep 03, 2018 1:26 pm
by TDITorque
iichel - can you please advise me?
Posted: Mon Sep 03, 2018 1:28 pm
by iichel
this is not making any sense to me. the info in the label does not match the label itself. is your VCDS a clone?
Posted: Tue Sep 04, 2018 12:02 pm
by TDITorque
I'm using a cable bought from AliExpress. Do you think its cable issue or something is wrong with my BCM?
Posted: Tue Sep 04, 2018 12:30 pm
by iichel
iichel wrote: Thu Aug 30, 2018 2:48 pm
3AB02BFF08A10000
013800006C2B
do this
Posted: Thu Sep 06, 2018 5:50 pm
by TDITorque
I tried updating the long code with 3AB02BFF08A100000
13800006C2B
26900080414F608C000020A000000000 and it got saved.
but when i viewed it again it was saved as - B02B7F09A1000000380000642B04900080414F6080000020000000000000 - strange!!
Needless to say everything (horn, window up-downs, steering controls etc) stopped working immediately after making the changes.
Posted: Thu Sep 06, 2018 5:56 pm
by iichel
throw away this cable and buy a proper one
