stereo and key remote central locking help please
Posted: Fri Sep 07, 2018 12:23 pm
by Uncle Fester
firstley thanks for letting me join have had a brouse and like what i see
bit of advise needed just got my daughter a 2005 9n3 1.4p s 75 16v
Central locking help , its only got one normal type key that unlocks the central locking on handle lock and starts car , how can i find out if its suposed to have a remote central locking fob as i believe some dont
stereo help , car has a RCD200 stereo that works fine but want somthing factory looking with aux in and maybe usb ( will try and add a pic below
Re: stereo and key remote central locking help please
Posted: Fri Sep 07, 2018 4:04 pm
by alexperkins
Welcome
The S doesnt have remote central locking - youll need to install a kit to make it remote central locking. Rclick.co.uk do some very good kits, and theres an install guide at the top of the DIY Guides section on the forum
Stereo wise, get something newer is the easiest option. A Pioneer SPH-DA120 is a very good choice
Posted: Fri Sep 07, 2018 4:26 pm
by Uncle Fester
Thanks for reply
not botherd about the remote locking realy as its not got it , just didnt know if it was suposed to have it or not
i was looking at the RCN210 stereo as it looks the same but has the aux and usb , was looking at others but as the orignal has sharp corners as the aftermarket ones ive seen have rounded corners so unsure about them fitting properley
Posted: Fri Sep 07, 2018 4:32 pm
by alexperkins
The RCN210 would work, so that would be a good option
All aftermarkets come with fascias for the corners. This series of polo uses a standard double din so single or double din aftermarket radios will fit without issue.
Posted: Fri Sep 07, 2018 5:11 pm
by Uncle Fester
Posted: Sat Sep 08, 2018 9:38 am
by gerinemo
Yep the RCN 210 is a perfect fit more than happy with mine
Links are for illustration I am not selling these
No recommendation just for illustration of parts required
The RCN210 was a good option for me also a polo 9n3
https://uk-polos.net/viewtopic.php?f=43 ... 38#p537738
Straight forward install just needed a quadlock to ISO adapter
https://www.ebay.ie/itm/CT20VW02-VOLKSW ... 58e13ea3ac
You will need the old radio removal keys
https://www.ebay.ie/itm/AUDI-VW-CD-PINS ... 5d3a1611e4
Speakers i bought
https://www.ebay.ie/itm/VW-Polo-4-9N3-0 ... 5d75b6c5fa
The radio I bought came with the can bus simulator
https://www.ebay.ie/itm/Car-Radio-RCN21 ... 363b18181f
Has micro SD card Slot USB slot Aux in + bluetooth
The First radio that they sent the display did not work
but after sending the photos of the radio working but no display they quickly dispatched another that worked fine ( did not have to send back the old one )
The radio removal tools were a bit flimsy and bent easily but I did get the old radio out wit them
There are two wires that need to be connected
A ignition 12v+
and an illumanation orange wire for the backlight to be connected to the lighting circuit
Both of these connections can be found at the cigarette lighter
the speakers were a little more difficult had to drill out the rivits to frr the old speakers
Adapters came with the new speakers for the wiring so that was easy
I had intended to connect the old speakers into the rear doors but have not got round to it yet as there is no wiring there yet
Posted: Sat Sep 08, 2018 2:45 pm
by Uncle Fester
Thanks helps alot
i like the stock look of the RCN210
so will i need a the can bus simulator or quadlock adaptor ( have the factory RCD210 )
Cheers Tim
Posted: Sun Sep 09, 2018 8:40 am
by gerinemo
Hi Tim
You will need both the quadlock adapter and the canbus simulator
The quadlock cable converts the existing volkswagen square connector into an ISO which the new radio RCN210 uses
the can simulator plugs into the ISO harness then into the back of the RCN210
I think the can simulator is to provide permanent live & prevent battery drainage issues ( I could be wrong though )
There are two wires from the quad adapter to be connected to the cigarette lighter 12v+ as a switched live and an orange cable that goes to the illumination around the ciggy lighter
and when the lights are on the radio display dims and the orange backlighting comes on
The fakra aeriel connector on mine ( rcn210) had a little silver attachment plugged in to it so I just pulled this out and the harness adapter fitted perfectly
i think there was 1 wire left unconnected ( maybe blue ) I think this may have been for a powered aeriel but again open to correction
Posted: Sun Sep 09, 2018 10:19 am
by Uncle Fester
Thanks for your help
