High idle
sm57ruo
- Drives: 2012 1.2 tsi
High idle
I am new to the forum, would like some enlightenment on the following;
I have a vw polo 2007 1.4 tdi, when I start the engine the car idles really high, up to about 1500 rpm?
Has anyone had the same problem?
Really need help on this
Thanks in advance
Thanks in advance
littlepolo
Re: High idle
Does it settle to a normal idle after warmed up?
Any other problems while driving?
Could be the coolant temp sensor.
sm57ruo
Re: High idle
No it doesn't settle the idle is still high even when the car is started for a while
Re: High idle
Clean the throttle body, check the EGR isnt blocked, change the coolant temp sensor
littlepolo
Re: High idle
Is a throttle body check/clean ever done as part of a dealer service routine?
Re: High idle
No sadly not
sm57ruo
Re: High idle
Could be a turbo or something to worry about?
Re: High idle
Very unlikely to be the turbo. Do what we’ve recommended and go from there
sm57ruo
Re: High idle
Quick update, haven’t changed anything as of yet, idle seems to come down just under 1000 rpm when driving for a bit
littlepolo
Re: High idle
Just under 1000 is still high. Should be around 680-750 depending on engine type.
sm57ruo
Re: High idle
1.4 tdi
marshall2810
- Drives: 2002 Polo E 1.2
Re: High idle
Loose airbox/hose perhaps?
Re: High idle
Try getting someone to check what the engine coolant temperature is claiming to be - or as suggested, just replace the engine coolant temperature sensor.
