Headlight bulbs on 64 6c
Andy1273
Drives: 1.2 tsi polo
Post by Andy1273 »
Hi all, sorry another thread on headlights I know but what ive searched are all for 6r.
Anyway I was wondering can I upgrade my headlights bulbs from the standard fitted ones. I'm not wanting to go down the LED route to expensive, just wondered if there are better bulbs out there?
Which ones are the type which appear blue in colour ?
Thanks in advance.
Re: Headlight bulbs on 64 6c
I think that the blue ones are just a style thing with very little or maybe less light output at the frequencies that let you see better.
I'd suggest just going for the higher powered normal bulbs like Philips Extremes which are burned at a higher temperature and so give out more light and whiter light getting closer to OEM HID used to be and probably OEM LED which will be "cold white" - these bulbs might not last as long as the ones with lower burn temperatures, but in my experience they last long enough and can make quite an improvement to what you can see ahead of you.
