Sensor below expansion tank
onepointfourbeast
Drives: Polo GTI 6R
Post by onepointfourbeast »
Hi Guys
I recently had a water leak which resulted in a few sensors getting wet. there is one sensor i cannot get to without stripping the car down which is just below the coolant expansion tank I was wondering if anyone knows the model number or can help me get the part code without stripping the engine as i will have to put it back together before i will get a chance to replace it.
Thanks in advance
Re: Sensor below expansion tank
Is it one of these parts?
Otherwise, it would be nice if you could illustrate exactly what sensor you're looking for.
What is the location, function, etc?
The coolant tank should be very easy to remove though. Just one bolt and it's held by a rubber in place.
