Hi
Can anyone tell me how to get the dash cluster out?
I’ve tried radio pins that seem the right size for the holes in the side of the dash but won’t budge!
Help!!
Many thanks
Rich
92 polo coupe dash cluster removal
Re: 92 polo coupe dash cluster removal
Pinched from another source:
two screws for the pod switch panel,unplug the switches as you draw it out. Steering wheel might get in the way,might wanna remove it. Pod itself is another two screws,lens tilts downward for easy way out once you've unplugged the speedo drive,if you need it out. Speedo plug is pulled out with a little catch on its side pressed with your thumb/finger. Bit fiddly but easy enough.
Telstar333+
- Drives: VW POLO MATCH 2001
Re: 2001 polo 6n2 ABS fault light - code V64
Hi, My ABS fault light has come on - fault code V64, recently had a 2nd hand pump fitted was ok for 3 weeks now same problem { cost of a new pump about £800 }
