What is the pipe that goes into the bulkhead just behind the ABS Pump?
Sarim
Drives: 9n3
Post by Sarim »
I'm installing a sub into my 1.2 9n3 and was wondering what the pipe is that goes into the bulkhead that's located behind the ABS pump. Looks like a black plastic pipe going through a rubber grommet.
Sent from my SM-G935F using Tapatalk
Re: What is the pipe that goes into the bulkhead just behind the ABS Pump?
Washer fluid pipe to the rear screen?
Sarim
Drives: 9n3
Post by Sarim »
RUM4MO wrote: Sun Nov 11, 2018 12:20 pm Washer fluid pipe to the rear screen?
I figured it was but wasn't 100% sure.
