2/4 windows auto close doesn't work
ebsp
Drives: 6C
Post by ebsp »
Hi there,
My first post here, after attempting to do my first mod. Really happy to have found my way to this forum - so much good content!
I was trying to install front footwell light in my 6C. The first attempt was to plug it to the BCM. After struggling with the tight space and the short cables connecting the BCM, I decided to take a shortcut and powering it to the interior celling lights. Works fine for now. Something strange happened after reconnecting everything though. The auto close function of the windows is only working in two out of four doors now (one front, one back). We had the BCM disconnected to asses if we could fit it there, but put it back in place after deciding to take the other approach using the interior light as the power source. Any ideas what could cause this problem? No error codes on VCDS
Re: 2/4 windows auto close doesn't work
With ignition on, hold every button in the second 'close' position for a couple of seconds. Then try again.
ebsp
Drives: 6C
Post by ebsp »
Works perfectly now. Thanks a lot iichel!
You're welcome buddy
