Start/Stop Issues 'vehicle power consumption high'
Jericho704
Drives: 2018 AW1 Energetic Orange SEL 115ps
Post by Jericho704 »
Hey fellow polo owners!
I seem to have an issue, with my 2018 SEL 115ps, with only 1600 miles on it, that has been persisting for at least a month now, where my Start/stop never triggers, and the display shows "Vehicle power consumption high"
No errors are displayed in the mfd or gauge cluster, but the crossed out start-stop symbol always appears when I stop at a light.
I have measured my battery voltage:
Car fully Off: 12.25V (this sound low?)
Car engine on: 13.76V
The air con is off, fans are off, radio is off, nothing is plugged into the 12V, USB sockets, or OBD2 sockets,
Rear demist is off, alongside with headlights and wipers.
Basically, everything that may consume power, I have turned off.
Anyone able to help? Or are suffering from this too? (other VWAG forums seem to show that I may be not alone)
Help a fellow polo owner out, all is appreciated :lol:
Re: Start/Stop Issues 'vehicle power consumption high'
Anything else consuming power, like a hardwired dashcams?
Don't forget that battery capacity is lower in the cold.
All those things consuming power - they're off now, but are they usually off? Do you do mainly short (<5 miles) journeys that don't give the battery a chance to recover? Have you left your heated wing mirrors on (easily done) - they should switch themselves off after a while.
We're all using the lights now (unless you have 9am to 3pm job) - Have you swapped your bulbs out for something a bit higher powered?
If it's no to all of that the you might have an underperforming battery or alternator. Has your mpg dropped off a lot lately (It does a bit in winter, but on a petrol doing at least a 10 mile commute,, I wouldn't expect more than a 5% drop).
Jericho704
monkeyhanger wrote: Wed Dec 12, 2018 4:50 pm Anything else consuming power, like a hardwired dashcams?
Thanks for all the questions!
the things that I normally use, are not normally off, I will try and keep them off long-term sans the lights, obviously.
I do short commutes, I may go for a motorway drive on the weekend to see if that helps.
The thing that does open my eyes, I have switched out my halogens, to aftermarket LEDs, I will change back to the old halogens, and Ill see if that helps.
But, I did have a good couple of weeks with the LEDs, and usb devices all on, with the start stop working fine, but that was during our warm September.
I have only owned this car since september, and I have done 1400 out of the 1600 miles on it, my MPG is relatively poor, sitting at 38MPG average, but my last continuous motorway journey over 15 miles, was over a month and a half ago, and I do like to bury my foot in the carpet, as there are majority A roads during my commute
Aftermarket LEDs should not be to blame, on the assumption that their output in Watts is less than the original bulbs output.
Andy Beats
Post by Andy Beats »
38MPG if you're burying your foot isn't bad, I'm barely managing that tickling the throttle.
Jericho704, I'm curious to know which halogen bulbs you have swopped for LEDs ?
Jericho704
RUM4MO wrote: Thu Dec 13, 2018 12:58 pm Jericho704, I'm curious to know which halogen bulbs you have swopped for LEDs ?
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1 These ones, have been good so far
Update
After taking my car out for a few consecutive motorway runs, the stop/start works, most of the time, must be a recharge issue, as I only do few, but frequent miles regularly.
vc-10
Post by vc-10 »
I have the same issues with my Fabia- too much city driving and the stop/start just gives up.
Jericho704
vc-10 wrote: Sat Jan 05, 2019 2:14 pm I have the same issues with my Fabia- too much city driving and the stop/start just gives up.
yeah, ive been scouring other VAG forums, and it dosent seem too uncommon
oh well :/
More life for our starters :D
Jericho704 wrote: Sat Jan 05, 2019 2:16 pm oh well :/
Every cloud etc etc?
Lower capacity of charge in the Winter, heavier use of heating (wing mirrors, rear screen and maybe heated seats) and lighting all take their toll. It's harder to restart a cold car (not that it's advisable to do so from a wear point of view), so the car's battery will not support stop-start until you've done 4 or 5 miles to get a healthy state of charge back and the engine is warm.
Wait until the Summer when you're hardly using your lights and heating and the battery can support a higher charge capacity due to higher ambient temps.
I never get that message for low battery charge, but my 13 mile commute each way probably supports battery recovery, even from my dashcams being on in park mode. There are times my stop-start won't cut in, usually at the starting 1/3 Of my journey.
If you have a short commute then your battery will always be struggling to maintain charge in the Winter without your alternator working overtime.
Jericho704
monkeyhanger wrote: Sat Jan 05, 2019 4:10 pm Lower capacity of charge in the Winter, heavier use of heating (wing mirrors, rear screen and maybe heated seats) and lighting all take their toll. It's harder to restart a cold car (not that it's advisable to do so from a wear point of view), so the car's battery will not support stop-start until you've done 4 or 5 miles to get a healthy state of charge back and the engine is warm.
That helps alot, with my daily commute only being 5 miles one way, and the need for heated rear window, mirror and front demist, alongside with full lights, and with the lower battery capacity, this is the perfect storm for my start/stop to cease working.
Andy Beats
Jericho704 wrote: Sat Jan 05, 2019 4:21 pm
My commute is 3 miles, stop/start has always worked so far.
This is with everything you've listed above plus heated seats on.
Jericho704
Andy Beats wrote: Tue Jan 22, 2019 3:29 pm
Congratulations.
I have booked an appointment with my local dealer, see if they can help.
awsm
Drives: 6c GTI
Post by awsm »
Jericho704 wrote: Tue Jan 22, 2019 3:31 pm
Congratulations.
Sorry for the necro bump, just wondering what came of your trip to the dealers? My car is the same, I do about 10 miles each way and I notice if the cars had a good drive on the weekend start stop kicks in after a few minutes Monday, Tuesday about 10 mins, Wednesday 15 mins and then it'll take a 30-40min+ drive for it to come on again. Considered booking into the dealers but get the feeling they'll just put it on a charger tell me no faults found and hand it back?
