Dear polo pro's
I'm in a bit of a situation here since I've got a Ibiza 6J in my shop that had the cluster replaced due to some faulty LED's.
Now the ABS unit is not functioning, I've already tried decoding myself but i just cant get the code right.
Can someone please shed some light on this or help me on a working code?
Here is the log of the car:
Thursday,20,December,2018,14:34:34:53651
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: VSSZZZ6JZBR163044 License Plate:
Mileage: 89210km-55432mi Repair Order:
Chassis Type: 6J (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZBR163044 Mileage: 89210km-55432miles
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 P HW: 03F 906 070 P
Component: SIMOS10.22H03 9871
Revision: --H03--- Serial number:
Coding: 001100D6202400080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070P 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 2F6D759976CCDF3A60-807A
2 Faults Found:
6068 - No Communication with Instrument Cluster
U0155 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 7
Mileage: 89203 km
Date: 2018.12.18
Time: 00:30:29
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 24 °C
Intake air temperature: 18 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 11.780 V
Unlearning counter according OBD: 37
Time since engine start: 0.0 s
Engine torque: 112.21875 Nm
Accelerator pedal travel-Accelerator position: 0.00 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: 7.875 °
10478 - Charge Pressure Control Actuator
P334A 00 [032] - Electrical Malfunction
Fault Priority: 2
Fault Frequency: 7
Mileage: 89203 km
Date: 2018.12.18
Time: 00:30:29
Coolant temperature: 63 °C
Intake air temperature: 26 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.984 V
Charge pressure actuator: specified value-PWM_BPA[0]: 0.000 %
POSN_DIF_BPA[0]: -0.00 %
Charge pressure actuator: adaptation for upper stop-VP_BPA_AD_TOL[0]: 0.8000 V
TQI_TCHA_PROT: 1023.96875 Nm
Readiness: 0010 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 071DFD39B2FCA77A88-8052
3 Faults Found:
03306 - Coding Not Valid
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 9
Reset counter: 2
Mileage: 89208 km
Time Indication: 0
Date: 2013.05.12
Time: 20:20:11
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x1496
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Fault Priority: 0
Fault Frequency: 5
Reset counter: 2
Mileage: 89208 km
Time Indication: 0
Date: 2013.05.12
Time: 20:20:11
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x1496
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 9
Reset counter: 2
Mileage: 89208 km
Time Indication: 0
Date: 2013.05.12
Time: 20:20:11
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x1496
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Part No SW: 6J0 820 043 C HW: 6J0 820 043 C
Component: Climatronic H07 0606
Revision: S0000000
VCID: 24478AB5270A6C628D-8070
4 Faults Found:
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 39
Mileage: 89106 km
Time Indication: 0
Date: 2013.02.06
Time: 02:36:33
00457 - Control Module for Network (J519)
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 33
Mileage: 89106 km
Time Indication: 0
Date: 2013.02.06
Time: 02:57:50
01317 - Control Module in Instrument Cluster (J285)
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 0 km
Time Indication: 0
01316 - ABS Control Module
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 0 km
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0394 083112312
Coding: 3C8829E888610100002000007E0B1DD800C0400F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 428B2C2DDD5E42529F-8016
Subsystem 1 - Part No SW: 6R0 959 801 N HW: 6R0 959 801 N Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 3130
Coding: 020000
2 Faults Found:
03302 - Response Closing Status of Passenger's Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 89203 km
Time Indication: 0
Date: 2013.05.12
Time: 19:28:42
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 254
Mileage: 89203 km
Time Indication: 0
Date: 2013.05.10
Time: 00:11:08
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10AirbagA01 H09 0020
Revision: -------- Serial number: 003GX00HY4V9
Coding: 003031
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4A9B040DED6E9A1257-801E
Serial number: 3495RRB405P0H4DQA0I-
Serial number: 3505RRB405N0H4DQB9Q1
2 Faults Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Fault Priority: 6
Fault Frequency: 3
Reset counter: 39
Mileage: 89203 km
Date: 2018.12.18
Time: 00:30:29
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Fault Priority: 6
Fault Frequency: 3
Reset counter: 39
Mileage: 89203 km
Date: 2018.12.18
Time: 00:30:29
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 802 HW: 6J0 920 802
Component: KOMBI H05 0404
Coding: 110A00
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 65C1D7B164B0556A5A-8030
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 422000
VCID: 70EFB6E5A37280C239-8024
3 Faults Found:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 38
Time Indication: 0
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 38
Mileage: 89203 km
Time Indication: 0
Date: 2013.05.10
Time: 00:00:21
00474 - Control Module for Immobilizer
Fault Priority: 2
Fault Frequency: 3
Reset counter: 38
Time Indication: 0
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0404
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADBA48D8DAE7A1277-803E
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 11210
Shop #: WSC 13765
VCID: 6FEDB5992A4C9F3A20-803A
1 Fault Found:
49-10 - No Communications - Intermittent
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70EFB6E5637280C239-8024
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J1 035 153 G HW: 6J1 035 153 G
Component: Radio H14 0203
Revision: R0000000 Serial number: SEZAZ2L1865529
Coding: 0501040002
VCID: 29599B814028B10ABE-807C
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Fault Status: 00111011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 89105 km
Time Indication: 0
Date: 2013.02.03
Time: 00:54:53
00871 - Bass Speaker Front Right (R23)
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 89105 km
Time Indication: 0
Date: 2013.02.03
Time: 00:54:53
End-------------------------(Elapsed Time: 02:03)--------------------------
56-Radio -- Status: OK 0000
Readiness: 0110 0101
Revision: --------
3 Faults Found:
000 - -
Fault Priority: 0
Fault Frequency: 11
Reset counter: 2
Mileage: 89208 km
Time Indication: 0
Date: 2013.05.12
Time: 20:20:11
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x1496
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
000 - -
Fault Priority: 0
Fault Frequency: 7
Reset counter: 2
Mileage: 89208 km
Time Indication: 0
Date: 2013.05.12
Time: 20:20:11
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x1496
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 11
Reset counter: 2
Mileage: 89208 km
Time Indication: 0
Date: 2013.05.12
Time: 20:20:11
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x1496
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Revision: S0000000
Coding: 020000
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 89211 km
Time Indication: 0
Date: 2013.05.12
Time: 00:05:58
Coding: 003031
Coding: 110A00
Coding: 422000
Serial number:
Coding: 11210
Shop #: WSC 13765
1 Fault Found:
Coding: 0000001
Coding: 0501040002
End-------------------------(Elapsed Time: 01:56)--------------------------
Another lost ABS long coding help
Re: Another lost ABS long coding help
Please post the advanced ID of the immobiliser and engine
