I'll go and check my car now. 9NZ3Y so that's a "Y" then?
Yup, it's the fifth "big" character on that sticker we're looking at. Of course, if everyone comes back and says they all have "Y"s there, then this theory will fall apart - unless the UK is being supplied totally out of one factory.
How do I know which month it was made in? I know it was in 2003.
Not being at my car just now I can't check for locations - but pretty sure the ash tray liner will be one place. Maybe some plastic mouldings on somewhere inside the engine bay, or maybe the underside of the wing mirror casings, would be places to look. Also, those neoprene shelf linings might have these markings - I find the one behind the ash tray the easiest to get out - it has two "plugs" on the vertical surface, but the bottom is just lying there and can be pulled up from one corner. Basically - there should be a series of stamps in the plastic - some of these - like the part number and the plastic type (for recycling) are constant, but others are stamps (well, the opposite of a stamp) inserted into the mould to tell you when the pressings were made. These re usually either a circle with 12 portions (numbered 1-12), or sometimes they're rectanglular(sp?). There will be a mark of some sort inside each segment. If there's only one mark - this will be the month it was made. If there are several marks, they should start in the 1st portion and continue in sequence - the last portion to have a mark in it gives the month of manufacture. Also, there will be a number (i.e. 02) possibly within the centre of the circle, or otherwise nearby that gives the year - hence, you can work out the year and month. Obviously, this will be earlier than the date of assembly of the car, but it should get us reasonably close to that date. After all, manufactuers don't hold inventories of parts any more (in theory)...
(I really need a photo of this!!)
I think the 3 point rear seat belt was an option along with a 3rd headrest.
Oh, OK - I didn't know this - so scratch it from my request above.
And I've been to the VW factory in Bratislava a few years agoin 1996. Can't remember which cars they were manufacturing at the time but I know one of them was the skoda felicia.
Now this would make a lot of sense (if it was the 9n platform version)...
Basically, I'll wait until there are a few replies here and pull everything together to see if we can work anything out about where our cars are being made and any other patterns that might emerge.
Thanks for your response (now just waiting for everyone else
Deek.
