Cornering lights and selective unlocking
Olaf__
Drives: 2014 1.4 match edition
Post by Olaf__ »
Hi there,
So I recently purchased a 2014 VW polo 1.4 match edition and I am over the moon with it! However, being a bit of a motor I couldn't help but want to tinker with it.
I purchased a copy of vcds and the suitable cable to investigate what I could mod/tweak.
I enabled needle sweep and a horn beep when locking, no problem. I also want to disable selective unlocking, so one press of the unlock button unlocks all doors. As well as enable fogs as cornering lights.
I have seen a lot of line about selective unlocking being under CCM 46, when I try access it I get the error "no response from controller"
Are the changes I want to make possible? If so how?
Cheers :D
Adam_013
Drives: 2018 Polo Beats 1.0 95PS
Re: Cornering lights and selective unlocking
Post by Adam_013 »
Olaf__ wrote:Hi there,
Cheers :D
I'd guess so, I managed to turn these features on with my Carista on a MY15 Polo SE. So I'd assume you can. However I know absolutely nothing about VCDS [emoji23]
Sent from my ONEPLUS A3003 using Tapatalk
Hi Olaf__ welcome
With your VCDS look at Address 09: Cent. Elect. (J519)
You must post here a full Autoscan to help you with your tweaks.
