Drl menace reduction
idriveapolo
I have a 2014 polo which is currently fitted with the standard
drls in the corners of the lamp blocks in the lower grill and which takes a really stupid and difficult to replace bulb (t20 wedge i think) which in any case has case I see no need for and in fact I think are just a menace. Due to the age of my car although they have to be fitted by law when new, they dont have to work afterwards as MOT test dont require testing of drls on any car made or first used before 1 march 2018 and for this reason i am considering several options to decrapify then.
I suspect this is another question that only cicolo / ciclo can answer but any replies are welcome unless i get stufff like "er why bother ,it naughty and other opinionated stuff. Im only asking about the tehnical possibilitys and while i am interested in remaining road legal, ultimately im not trying to make this other peoples problem.
Option1 is to find out how to disable the bulb warning system either for the whole car or just for the drls depending on what is possible (advice needed) because then i can just disconect / remove / whatever them and that will then allow someone to just reconnect them again should they ever need to. (im not interested in solutions which turn off the power to them for this reason as id much rather leave the cable powered up just in case). Can anyonone tell me how to disable bulb warning for this? (and no im not wedging in resistors in place of lights/bulbs as i would idealy just want the job nice and clean if i were to use this option)
Option2 is to replace the lamps housings for some thing that takes a ba15s type bulb like I believe the pre facelift (smiley ones) did using bulb holder number 6r0953123a because ba15s bulbs come in all sorts of sizes and previous tests show that my bcm does not complain when I use bulbs as low as 5w. Can anyone recomend me a Drl enclosure which take ba15s bulbs (i dont have or need foglight currently) of the angular type which will fit post facelift polos either oem or aftermarket? This solution would reduce confusion and glare and menace factor to other road users without needing to alter the cars settings.
Option 3 The bulb holders on the current drls lighting blocks look suspiciously similar to h8/9/11 bulbs has anyone tried this and if so which one fitted the best. The reason im asking is because some of these bulbs are A more optainable than the current peanut bulbs and B some of them I think can sometimes be bought in 24v versions from truck places which will obviously be nice and unobtrusive at 12v and should still draw enough to keep the bcm's bulb failure system happy again with no modifications plus undervolted bulbs last a long time.
Option 4 If i am stuck with whats already on the car (ie because options123 are not viable) then i may as well investigate makeing them work in a usefull way by making them stay on when the sidelights are switched on and engine running in order to provide provide a little extra lighting at times of dusk or in towns etc a bit like what dim dip used to do before the eu interfered with our laws during the 90's instead of the illogical situation of actualy having them go out and making the car go dimmer when one turns on the light switch be because its getting dark or else being tempted to drive in low light situations with just the drls on at the front and hope anyone behind you is paying attention. This is an utterly ridiculous way to do things and im glad to see that later cars do actually keep the drls switched on until main/dip beam is switched on. THIS is how i want my drls to work if cant do any of the other options! HOWEVER all my lights go throught the bcm and experiments with removing the tfl wire or the complete light switch do in both cases cause the drls to go out but all the othe lights to come on instead, this leads me to wonder if the bcm would complain if I were to modify to tfl wireing to keep the drls on until main /dip beam is switched on. I did think about getting the tfl wire and just conecting it to the ignition live terminal via a relay switch which would be wired so as to disconect the tfl wire when the headlight switch is turned to main/dip but I was unsure of what the bcm would think of me for trying to pass power to drls while the sidelights were turned on. Being german i wouldnt be suprised if the bcm would think "this light switch is acting stange, ill do something even stranger or costly" however i dont know and i may be ok to do this and some one may even sell a light switch which already has the DRL contacts aranged to behave in this manner. Heeeeeelp
Re: Drl menace reduction
Hi, welcome.
IMHO the Germans do extraordinary things, like many others on this planet in this exciting 21st century.
I don't know if your current BCM is capable of managing the DRLs so that they are permanently lit in all switch positions (without IC faults). Being a 6C maybe the Germans already thought previously that you would want this condition for your DRLs.
Do you have any kind of diagnostic tool? VCDS autoscan?
The 6C is not my territory, I hope someone can help us in this matter. I think it's better that you make your question in the 6R/6C section.
Best regards
Fernando
Best regards
Fernando
veteran
I've DRLs on my own 6C and, like you, regard them as a bit of a pain in the proverbial backside; apart from on gloomy winter days, they're a dreadful waste of energy, IMHO, and I find it particularly annoying that they're on when the car's parked and you're in the car listening to the radio or whatever. I nevertheless accept that, rightly or wrongly, they're now required by law, and although mine are the non-LED types I've no intention of ripping them out and/or replacing them.
A year or more ago, I came across a legit method of disabling the DRLs, it not involving any physical disconnections. I think it was published somewhere in these forums. Anyway, it would satisfy your Option 1, I feel sure. I'm not convinced you'd still be road-legal if you disabled yours, though. I've a record of that procedure somewhere and could re-publish it in this particular Topic, if you wish.
massimo23
- Drives: Polo Beats 2017
There is a setting where you can disable the drl lights when parked.
Thats how mine work after I did the adaption.
should be this:
Control unit: 09 Central Electrics:
Security Code (31347):
Adaptions:
Daytime running lights:
Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten: active
should be this:
Adaptions:
idriveapolo
Cicolo My Daft your right Ive posted this in the wrong place ie now cut and pasted it into to the right section due to me being new here
Veteran Due to the age of the car DRLs are currently not a MOT requirement on any car first made or used before 1 March 2018 even though its new enough to require them to be fitted as new. Your right in thinking some one could whine and winge or bring that date forward in future and this is why Options 1 and 2 are my favorite because one can quickly reconect it all or change bulb size etc with out having to mess around with un-neccessarily complexity each time i think the do-gooders are close.
I Also have no intention of going over to leds as they are just horrible and anti social. In option 2 I was hoping that there was ANOTHER incandescent light housing used on a different model or year (as long as its suitable for same kind of bumper) which used ba15s bulbs rather than these t20 horrors which are only available in one size and one voltage. Ba15s bulbs come in all sorts of sizes and voltages (the dimmer the better) and no BCM mods neccessary
just put in the least anti social bulb you can
Massimo23 I once did borrow vcds and I think the setting you are reffering to is the one that turns the DRLS off when the hand brake is applied. Usefull if you sit in car parks in winter time keeping the car warm radio on etc, However its not so helpfull as the car would tend to roll away when checking the lights from outside making lighting the least of your problems!
Its this kind of ill thought out EU meddling/do-gooderism which is why I voted "LEAVE" because all they do is cause problems for the rest of us!
I solemnly promise that I haven't moved this thread to the 6R/6C section, and that I would never have done it.
It is highly probable that it has been moved by iichel.
By the way, although the 6C is not my territory doesn't mean that I don't have extensive knowledge of this model.
I beg a little respect in the ways of saying things, this a international/world forum, I wouldn't want to be forced to show my power. Thank you.
Political or related comments aren't allowed. (even if I was in favor of such a comment
idriveapolo
Its perfectly acceptable for my post to be moved from the wrong place to the right place as long as they can be found and I know where they are.
Regretably I dont have current use of vcds. Also I dont have the 5 digit code BCM which one needs for changing certain settings at present.
To give one a clue to narrow it down what bcm I have Ill describe the feature best I can. 2 door , Electric windows, bluemotion stop start system, Uses a real key not a remoteflipper (and I dont believe one can be programmed in either), proper light bulbs (not an led anywhere) non electric mirrors with led repeater, no extra lights exept rear fog light, daft radio which also does things it shouldnt like control the car, tpms, abs, esc (via daft radio). All the lights have bulb failure monitoring exept numberplate and reverse lamps. From this you should be able to narrow down what bcm I am likely to have to a couple or so models??
On my car however it works in a very counter-intuitive way : Light switch set to off (with engine running), drls on. Turn on side lights, drls now out and side lights are so dim that it feels like you have turned the lights off again altogether (even though you have "technicaly" turned them on) and now the only thing you can see at night is the dasboard lights glaring at you (which you cant adjust without fiddling with the radio Whaaat the...!), Turn on main/dip, and at last sensible behavior! (BTW I am struggling to understand why I cant see sweet nothing with 2x5w sidelight bulbs from inside the car when I have a clear windscreen and and I could see plenty of things when I rode my bicycle with a single 2.4w bulb before. Even Citroen cant do worse than this!)
To my way of thinking, as one starts to turn the light switch round it should get bighter and brighter with each position click.
I have determined that on my car the DRLS actually make good town lights as long as no one is coming from behind and will allow me to drive safely at speeds upto 30-40mph on country roads at night (as long you let eyes recover from everyone elses led dazzle first and no one else is about). I did also consider just swapping the front side light wires with the drl wires but I suspect it would just cause other problems. I mean 2x 20w is quite a lot of power for some thing thats only suposed to be noticed in daytime
Seriously though are all european cars quirky/stupidly thought out? do I have to go back to buying a rust bucket from ford or what?
veteran
Idriveapolo,
A couple of points: First, I think I'm right in saying that the Law's requirement for DRLs, if fitted, to be operative while the car is on the road has, of itself, little to do with the satisfying of an MOT requirement. Second, although there might be a method for temporarily turning off the DRLs by using VCDS (such as mentioned by massimo23), the solution that I myself remember seeing does not (if my memory serves me correctly) involve VCDS. If you just give me the time to find the note I made way back about this, I'll post the solution here. Do appreciate, though, that it's a method where the DRLs are permanently disabled.
idriveapolo
Are you saying that even I could pass the MOT i might still get trouble from the police and similar highways authorities?
Actually it was Alexciclo wrote: Tue Feb 12, 2019 5:23 pm I solemnly promise that I haven't moved this thread to the 6R/6C section, and that I would never have done it.![]()
The DRLs function is like an altruistic favor that you do to others, so they can see your car with clarity (that's why they are more powerful than the side/parking lights). In no case are oriented to help the rest of the lights in better lighting, nor to drive exclusively with them during the night under any circumstances.
As you already know, also under no circumstances (except in the Scandinavian countries) it is allowed to drive exclusively with side lights.
Example of this altruistic favor:
Typical pedestrians who are deeply focused on their smartphones looking at essential things for their lives and cross the zebra crossing without looking if it is possible to do so.
It's proven that DRLs save lives.
IMHO, it would be good if you also did this altuistic favor to others and you rethink the way you want your DRLs to work.
Ok, thanks.iichel wrote: Tue Feb 12, 2019 7:18 pmActually it was Alexciclo wrote: Tue Feb 12, 2019 5:23 pm I solemnly promise that I haven't moved this thread to the 6R/6C section, and that I would never have done it.![]()
It is highly probable that it has been moved by iichel.mcp.php?i=139&f=56 11 Feb 2019 22:22
veteran
In response to your question Idriveapolo, yes!
In the meantime, I've found the note I kept from way back, and I reproduce it here:
Disabling the Daytime-Running Lights
1. Insert the key in the ignition, but don't turn the key at all.
2. Turn the headlight switch on the RHS of the dashboard (this assumes a righthand-drive car) to the '0' position unless it's already there.
3. Operate the direction-indicator stalk as if to turn left and then pull it toward you, as if to do a flash.
4. Turn the ignition on, but not the engine.
5. Wait at least 4 seconds and you should then hear three beeps. This will indicate that the DRLs have been deactivated. Check that they have.
Please understand that if you decide to try this out, you do so entirely at your own risk. Don't come blaming me if it doesn't work. I've never tried it out myself. Bear in mind that it's not known how to re-enable the DRLs, should you ever need to (though I guess there must be a method).
I'd strongly advise that, before you attempt this, you do some research online yourself to determine what the Law says about using DRLs in the UK. My understanding is that if DRLs are fitted they must be on and fully working while you are driving around.
idriveapolo
veteran ive already tried that one, only works on earlier models.
ciclo In my way of thinking and many others in the uk, if somebody insists on not looking where going then they probably need knocking over. Also this idea of being seen and creating some kind of competition on who can attract the most attention blurs the lines of responibility which is dangerous in itself. For example if some one wants to cross the road whos responsibility is it that they dont get run over? The idiot not looking or the motorist for "hiding" from him. Also when im driving along the road and see some one in the middle do i brake as I did before or do i say to myself "he will see me coming because ive got daft lights fitted?" (dont forget its also dangerous to brake uneccessarily in case the person following you playing with some dashbord accessory or phone etc, becuase after all hes got air bags, abs, radar, you name it and many other excuses for being divorced from the realities of driving) . Besides what are we all to do at night time about animals that escape on the road, pedestrians, cylists, potholes, and all the other unlit risks on our roads how does a culture of "lights solves everything" deal with all that ? Will the farmer be required to put leds on all his animals just in case they escape and what if the batterys go flat in the mean time? Its because of all this ive had to give up cycling due to the fact one can no longer guarantee the motorist is even awake whereas before one could cycle quite safely knowing the biggest distraction any motorist could have was turning a cassette tape over!
This is serious! The more excuses we make for dumb people the dumber they will get and this emerging culture is more dangerous than people realise. As some one who is spanish you have probably seen our drunken louts embarassing both themselfs and my country on holiday. This is because Uk authorities always pick up the pieces and let them getaway with it instead of giving them a good kicking and so of course they think they can do it elsewhere. This whole culture of passing blame onto other people is far to prevelant.
idriveapolo
In the uk one can drive with sidelights A in the day time whenever they like B in built up areas where there are street lights and some still do though far less often than in the past.
I believe that in russia people would also use sidelights in towns in the past at night in a similar way to the british in former times
In the 90's The uk government decided that that dim/dim lights (town lights) should be fitted to cars to increase ambient lighting and visibility of drivers who considered main and dip beams to be too powerful to use in built up areas like so as not to shine through peoples windows and the like. These would often light up the main or dim filaments either at a reduced intensity or could use a seperate filament as one wishes to design it and only worked when the engine was running and sidelights were on and were of similar intensity as many drls today.
This idea was too sensible for those in brussels so they took our government to court and this requirement was dropped because the car manufactures complained that they would have to make our cars differently EVEN though our cars already have to be completely redesigned anyway for the simple reason we drive on the other side of the road IE new dash board, pedal assemblys and linkages, spedometers showing mile instead of kilometers, lights already having to be made to not dazle cars passing on the other side, wiring looms changed to reposition the controls and even carpets and footrests and other stuff too.
Well, I'm (already was) absolutely convinced that your last comments are full of truths.
I'm also convinced that a diagnostic tool such as VCDS (for example) would solve part or totally this issue.
I don't know if the bulbs holders 6R vs 6C are compatible between both types of fog lamps 6R vs 6C.
The connector that go to bulb holders is the same for both 6R vs 6C.
If this is possible, there will be many more possibilities for DRLs 6C.
Must be investigate the BCM coding and adaptation channels.
