Disable indicator flash when locking/unlocking
idriveapolo
Post by idriveapolo »
How does one stop the indicator lamps from flashing when I lock or unlock the car .
My car only has a key that you put in the door lock so its not like I need to confirm ive locked / unlocked the car from the other side of the carpark or particularly need to anounce to people that Im capable of locking and unlocking the car etc
Re: Disable indicator flash when locking/unlocking
If you have VCDS, you would be able to untick or deselect this I’d Think.
idriveapolo
I would have thougbt so to. Last time I borrowed vcds half of it was in german and quite a bit of it required access codes to unlock the settings. I just want make my car less poncified though, not buy more poncery as that would be counterproductive
massimo23
Drives: Polo Beats 2017
Post by massimo23 »
Hi there try this and see if it works.
Change the setting from active to Not active.
Central Electric 09
adaptations
Security code : 31347
Acknowledgement signals:
Optische Rueckmeldung Komfortschliessen: Not Active
idriveapolo
It doesnt make a difference
