Hello,
I have a question in relation with the auto headlight switch for an Ibiza 6J.
At the moment I have the rain/light sensor installed but the car is made in 2010 and doesn't have the light switch installed.
Can anyone help me how to retrofit the original light switch with the correct wiring.
I have BCM 6R0937087F, is this BCM capable of the auto light mode or do I need an other type?
In the Ibiza 6J I had before, I had installed an automatic light switch out of China which was just plug and play but not original, at that moment I didn't want to do it original because the sensor needed retrofitting also but I think this car does already have the sensor for the climate screen.
Thanks a lot already!
Seat Ibiza 6J automatic lights witch LH/CH
Re: Seat Ibiza 6J automatic lights witch LH/CH
No you'll need a 7H0 937 089/090x BCM or even better, the 7E0 937 089/090x bcm. Keep in mind that the wiring might differ from a 6R polo, if I remember correctly the Ibiza had some kind of auto light from factory available.
