Do i have auto full beam headlights?
morty192
Drives: Polo SE
Post by morty192 »
Hello all, I have a 2019 Polo SE 1.0 65bhp. The only optional extra added to the car was front and rear parking sensors. I know I have auto lights but how do I switch the auto full beam on? If I have this feature?
phillos
Drives: '19 Polo (AW)
Re: Do i have auto full beam headlights?
Post by phillos »
I dont think the GTI has it, as such I doubt yours have. I've not seen it as an option anywhere.
It needs a camera mounted in the windshield behind the rearview mirror.
Andy Beats
Post by Andy Beats »
That would need the 'dynamic light assist' option.
You won't have that standard, I'm not even sure it's an option on the Polo SE.
Adam_013
Drives: 2018 Polo Beats 1.0 95PS
Post by Adam_013 »
Not standard on the SE as said above, you only have auto lights. Note that they do not come on when it rains / wipers are used either. You have to do that manually.
phillos
Post by phillos »
Adam_013 wrote: Thu Mar 07, 2019 2:48 pm Not standard on the SE as said above, you only have auto lights. Note that they do not come on when it rains / wipers are used either. You have to do that manually.
Yeah, that requires the 'rain sensor' correct?
Andy Beats
Whether it's the basic 'light assist' or fancier 'dynamic light assist', VW say a camera is mounted on the windscreen.
They specifically use the word camera, not just a sensor.
Adam_013
Post by Adam_013 »
Correct, yes.
I'm not aware of any high beam assistance on the Polo AW. There is however the option for an auto dipped beam on the Polo AW.
Andy Beats wrote: Thu Mar 07, 2019 2:39 pm That would need the 'dynamic light assist' option.
Dynamic lights are lights that swivel with steering input (My Golf R's Xenons have this), you need "high beam assist" - my wife's A1 had this, but never used it as you had to set it at the start of every journey by pulling back on the indicator stalk when you started the car to activate and I'd always forget.
In the windscreen facing end of the rear view mirror mounting, where the light/rain sensor (If you have one) for auto lights and wipers is, there was a camera/light gathering sensor underneath (at the front end of the adjustable knuckle for your rear view mirror, facing the windscreen) to detect oncoming traffic so that high beam could be switched on and off automatically.
Andy Beats
monkeyhanger wrote: Thu Mar 07, 2019 3:43 pm
Had the auto high/dip function with dynamic cornering lights on my 320ED, it was far too slow to dip and using the stalk manually was faster.
In the wife's Sportage though, it works absolutely brilliantly, dipping and going back to main beam perfectly.
Wouldn't pay extra for it though, no chance.
peeceeuk
Drives: Snazzy red GTi
Post by peeceeuk »
What about as you have another car in your sights as you approach them from the rear?
Does such a system dip then and how soon?
Adam_013
Post by Adam_013 »
peeceeuk wrote:What about as you have another car in your sights as you approach them from the rear?
Parents A1 does this, however can be very slow to respond.
Andy Beats
peeceeuk wrote: Thu Mar 07, 2019 7:32 pm What about as you have another car in your sights as you approach them from the rear?
In the Kia, it works perfectly.
It doesn't dip for road signs, but if it sees a red light in the distance it will dip instantly.
So far, it works exactly as any decent driver would.
