UK-POLOS.NET - THE VW Polo Forum • Installing Remote Locking
Page 1 of 3
Posted: Sat Mar 30, 2019 1:05 pm
by OwenNorton
Hi, I have a 2012 VW Polo 6R, and it comes with central locking via key, but just not remote locking. I have bought a kit from eBay that I am looking to install, but from spending a couple hours reading forums, everybody seems to say something different about this car.
From what I can understand, I have to connect this kit to the central locking pump, which is located behind the rear lights at the right, but I need to install some kind of resistor too.
It all seems a bit confusing with everyone saying something different, can somebody possibly walk me though / provide a wiring diagram or photo here directly instead of linking me to a different forum post. Trust me, I've read them all already haha.
Re: Installing Remote Locking
Posted: Sat Mar 30, 2019 2:02 pm
by RUM4MO
That is either a poor translation or that kit covers cars including ones with air powered locking. VW Group has not used that system for many many years, the central locking is electrical.
Keep searching as I'm sure that others have wanted/tried to convert standard central locking to remote central locking on these Polos including earlier versions.
Posted: Sat Mar 30, 2019 2:28 pm
by OwenNorton
Posted: Sat Mar 30, 2019 7:13 pm
by alexperkins
Owen - I’ll help you with this on Monday if you can hold fire
The kit you have bought will work with some changes
Posted: Sat Mar 30, 2019 7:15 pm
by OwenNorton
amazing! thank you Alex :)
Posted: Sun Mar 31, 2019 5:00 pm
by Ibrahim11
alexperkins wrote: Sat Mar 30, 2019 7:13 pm Owen - I’ll help you with this on Monday if you can hold fire
I also have a 2011 polo 6r and am thinking of doing the same with an Rclick kit or the one from ebay. I would be grateful if you posted instructions on this thread so I can refer back to it! :)
Posted: Mon Apr 01, 2019 4:09 pm
by OwenNorton
Ibrahim11 wrote: Sun Mar 31, 2019 5:00 pm I also have a 2011 polo 6r and am thinking of doing the same with an Rclick kit or the one from ebay. I would be grateful if you posted instructions on this thread so I can refer back to it!
kit off eBay has just arrived, the remote seems to be high quality, and looks nice too. Looks a bit like a clone of the Audi keys, much nicer than most of the kits online. If I manage to get it all working I'd definitely recommend that one!
Posted: Mon Apr 01, 2019 4:41 pm
by alexperkins
Scan or photo of each page of the instructions please Owen :)
Posted: Mon Apr 01, 2019 5:25 pm
by OwenNorton
alexperkins wrote: Mon Apr 01, 2019 4:41 pm Scan or photo of each page of the instructions please Owen :)
see attachment :)
Posted: Wed Apr 03, 2019 8:15 pm
by OwenNorton
what are my next steps?
Posted: Wed Apr 03, 2019 8:16 pm
by alexperkins
Ok so it’s the same as the rclick guide in the DIY section. 180ohm resistor but the wire colour is different. I’m double checking my notes and will come back to you
Posted: Wed Apr 03, 2019 8:19 pm
by OwenNorton
alexperkins wrote: Wed Apr 03, 2019 8:16 pm Ok so it’s the same as the rclick guide in the DIY section. 180ohm resistor but the wire colour is different. I’m double checking my notes and will come back to you
cheers mate!
Posted: Wed May 01, 2019 4:39 pm
by OwenNorton
Hi Alex,
any update on this? wanting to get it fitted soonish :)
thanks
Posted: Wed May 01, 2019 4:43 pm
by alexperkins
Sorry mate I totally forgot about this. Let me check :)
Posted: Wed May 01, 2019 4:44 pm
by alexperkins
VW Polo Mk V remote central locking unit instructions.
Remove boot release handle (unclip on side).
Remove screw and driver’s side kick panel, on right below steering wheel.
Locate wiring loom coming from door.
(Thin) blue wire = central locking control. (Green/yellow wire prior to May 2011).
Negative trigger. Pull this directly to ground to lock or via 180 Ohms to ground to unlock. Use 5 A cable lock connector.
(Thick) Red/yellow wire = +12 V permanent. Use 15 A cable lock connector.
(Thick) Brown wire = ground. Use 15 A cable lock connector.
