Footwell light polo AW 2018
tfpc123
Drives: VW Polo AW 2018
Post by tfpc123 »
Hello guys
I'm new to the forum. My name is Tiago and I'm from Portugal.
I bought my VW Polo AW in 2018, and wanted to install lights on the feet (I'll buy the kit at carsystems). Has anyone here done this retrofit? I already went to Elsa online, but the information is wrong, because my BCM has 3 connectors, and in Elsa online says that my car only has 2 connectors, I do not understand why ...
I have connector A and C with 73pins and B with 46pins.
My BCM is 2Q0 937 089.
tfpc123
Re: Footwell light polo AW 2018
Post by tfpc123 »
Has anyone made this retrofit?
roywolfey
Drives: 2018 Polo GTI +
Post by roywolfey »
I can't help, but noticed a retrofit cable kit here:
https://www.kufatec.com/en/all-products ... -mqb-42185
tfpc123
Post by tfpc123 »
roywolfey wrote: Thu Apr 04, 2019 1:44 pm I can't help, but noticed a retrofit cable kit here:
My problem is in the adaptation channels ... Strange no one has yet done this retrofit ...
tfpc123
Post by tfpc123 »
https://imgur.com/P4taXxG
T73a
T46a
T73b
Three connectors.
tfpc123
Post by tfpc123 »
ciclo wrote: Fri Apr 05, 2019 2:12 pm Image
T73a
T46a
T73b
Three connectors.
Excelent news ;)
tfpc123 wrote: Fri Apr 05, 2019 10:28 am
Maybe the following information may be helpful for you, it is applicable for the Golf mk7 and mk7.5, I don't know if it is applicable in the Polo AW.
Search term in BCM adaptation channels = FR
Footwell light = Fußraumbeleuchtung
Example for Golf:
Footwell lights + Ambient lights (2 front + 2 rear ... Ref: 5G0947409)
Address 09, SECURITY ACCESS--> 31347
Adaptation
Leuchte30FR LC72-Lasttyp 30,not active ,16 (36-LED Kleinleistung)
Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16 (02)
Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,16 (Always)
Leuchte30FR LC72-Lichtfunktion A 30,not active ,16 (Footwell Light)
Leuchte30FR LC72-Lichtfunktion B 30 ,16 (Terminal 58xs dimmer) -power supply for ambient lights function. if lights ON (AUTO-ON/side lights/low beam in light switch positions)
Leuchte30FR LC72-Lichtfunktion C 30 ,16 (Interior Lights) -power supply for footwell lights function. When open the doors.
Leuchte30FR LC72-Dimmwert AB 30,0 ,16 (I choose 60) -60 is my setting, ambient
Leuchte30FR LC72-Dimmwert CD 30,0 ,16 (I choose 100) -100 is my setting, footwell
Tip for all those who read this post:
You all should / it would be good for all of you (POLO AW owners) to share the adaptation channels when you make successful modifications.
tfpc123
Post by tfpc123 »
Hello guys.
Thanks to the help of my friend n4s and Helder from Portugal, we got active the footwell light in the AW Polo;)
These are the following adaptation channels:
  • Foot - Foot well lighting = installed
  • 2C64 - Dimmwert AB 32 = 100
  • 2C64 - Fehlerort_mittleres_Byte_DTC-DFCC_32 = 2
  • 2C64 - Type_Of_Load_32 = LED Kleinleistung ohne Open Load Diagnose
  • 2C64 - Light_Function_A_32 = Footwell light
tfpc123
Post by tfpc123 »
ciclo wrote: Wed Apr 10, 2019 5:23 am
Example for Golf:
Adaptation
Hi :)
Thank you for information, In my post below I have the adaptation channels, and I already have light in my AW Polo :)
Thank you all
tfpc123 wrote: Wed Apr 10, 2019 2:08 pm Hi :)
Thank you all
Great!! 8)
A big hug to Ruben.
Internet starts to be very small ... :lol:
tfpc123
Post by tfpc123 »
ciclo wrote: Thu Apr 11, 2019 3:59 am
Thank you all
Great!! 8)
A big hug to Ruben.
Really small :roll: :roll:
Digonho
Drives: VW Polo GTS
Post by Digonho »
tfpc123 wrote: Wed Apr 10, 2019 2:04 pm Hello guys.
Em português pra tu: CRIE UM PASSO A PASSSO POR FAVOR :D
if you can show where the lights fit, thank you
grpipolo
Drives: GTS
Post by grpipolo »
My name is Gabriel and I’m from Brazil.
I’m also trying to retrofit the footwell lights on my 𝐏𝐨𝐥𝐨 aw.
I installed them and did the coding with vcds. Everything is working, except that the option to reduce/increase the brightness is not showing on my screen...
do you have any ideia what’s happening?
Thank you!
monkeysllrultheworld
Drives: 2020 AW
Post by monkeysllrultheworld »
Hey there
Did you fit lights on the back seats also?
