Throttle Stick
NathanPeter
Drives: 2019 SE Tech Edition
Throttle Stick
Post by NathanPeter »
Hey Guys
Have literally just noticed a problem with my new Polo SE I picked up a couple of weeks ago. When depressing the throttle fully the car seems to get full power but the pedal seams to stick and if you put a bit more pressure on it it seems to move an extra centimetre or so and I’m unsure if it alters the power
I’m going to give the dealership a ring but was just wondering if anyone else has had this issue? And if so what it was? Or even if it is normal and some sort of sensor I’m unsure
Andy Beats
Re: Throttle Stick
Post by Andy Beats »
This is normal.
If you're using the speed limiter function, using this extra piece of throttle overrides the speed limiter (accompanied by a warning noise) and allows you to speed up to overtake someone.
Then as soon as you release the throttle back to its normal position, the speed limiter function will resume.
NathanPeter
Re: Throttle Stick
Andy Beats wrote: Wed Apr 03, 2019 2:10 pm This is normal.
Perfect thank you, I’ll take it for a drive and test it out. I wa freaking out cause there’s only 900 miles on the clock
Re: Throttle Stick
NathanPeter wrote: Wed Apr 03, 2019 2:14 pm
Also, if you have drivers modes on your model and you're driving like miss daisy in eco mode (and only getting 50% throttle response over the travel vs sport mode), if you bury the pedal past the click area towards the end of the pedal travel, the driving mode is overridden and you get full throttle response while you're beyond the click.
jdunstone16
Drives: VW Polo Beats 2018
Re: Throttle Stick
Post by jdunstone16 »
Hi
Mine does the same thing which I believe is normal.
The point of it seems to be that when the speed limiter is activated, adding that bit of pressure causing the accelerator to go that bit further, the speed limiter is deactivated if you need a bit more speed suddenly
Andy Beats
Re: Throttle Stick
jdunstone16 wrote: Wed Apr 03, 2019 9:55 pm Hi
Yes, which as as I said two posts up.... :wink:
