My first post so apologies if I don't get this quite right. Was wondering if anyone could help diagnose the starting issues on my 2007 1.4 Polo 9N3.
Started car last weekend and drove a few hundred yards until it died on me. Tried jump starting to no avail. Even tried push starting (with the help of a few neighbours) as we rolled car back home, but it would not turn over.
Have checked battery (all good) and changed fuel pump. Although engine cranks just fine she still does not want to turn over.
I am getting fuel and spark with key turned all the way. (Good spark would presumably rule out crank/cam sensors which I've heard can go bad on these). Air filter is almost brand new.
I am stumped, could it be an ignition (switch) related issue? Any assistance thankfully welcomed.
Regards,
Hammers
2007 1.4 Polo 9N3 not starting
Re: 2007 1.4 Polo 9N3 not starting
One error in your wording could be that “not turning over” means not firing, is that correct?
While you say that you are getting fuel injected into the engine, is it still being injected under high pressure or in other words, can you hear the electric fuel pump running while cranking the engine over? If “no” then is the pump relay working okay?
Edit:- engine timing or timing belt might be another aspect to consider.
Lester
- Drives: 2008 Polo 9N3 1.4 BUD
Try scanning it with a scan tool and see if you get any hints from the codes.
