Do my polo's headlight beams look correct?
Posted: Thu Apr 11, 2019 10:53 am
by Jericho704
Hey!
See the images attached, when I am far from a wall, you can see that the (passenger) left low beam, has a higher flick up, compared to the right low beam.
I thought that both beams would have an equal flick up?
Does anyone know if this is correct or is there something wrong with my (driver side) right low beam?
Edit; they look much less different and more similar, the closer I am from a wall, also, if any other 2018 Polo owners with the halogen headlights, have the same pattern
Any and all help is appreciated.
Below are pictures, close to the wall, and further away, with a red highlight to show the difference
Re: Does my polo's headlight beams look correct?
Posted: Thu Apr 11, 2019 11:29 am
by peeceeuk
Aren't headlights aimed towards the kerb slightly and might this explain what you see?
Posted: Thu Apr 11, 2019 11:42 am
by Jericho704
peeceeuk wrote: Thu Apr 11, 2019 11:29 am
I was aware that they flick up to point towards signs and to not blind oncoming drivers, never knew about the kerb thing tho
Also, if any other 2018 Polo owners with the halogen headlights, have the same pattern (ill add that to the op)
Posted: Thu Apr 11, 2019 11:48 am
by phillos
In my understanding, both headlights should be the same level. Thus one of them is either too high, or too low.
Edit: I’m stupid. They are obviously level, they just have different light patterns. In HIDs you can adjust the focus, maybe halogens can too?
The kerb thing, hmm, mine has always shined straight. They seem to shine more towards the kerb, because of the “kink”. Not because of the direction.
Posted: Thu Apr 11, 2019 2:40 pm
by Jericho704
phillos wrote: Thu Apr 11, 2019 11:48 am
haha no worries
Unfortunately, I can only raise or lower the headlights regarded to the load in the car, I cant focus them (at least what I know of)
Re: Do my polo's headlight beams look correct?
Posted: Mon Apr 15, 2019 9:09 am
by Andy Beats
Headlights are a big problem in the Polo, standard alignment is ridiculously low and dangerous.
Basically, just align them to your own tastes (as long as you're not dazzling anyone).
